Difference in timing belts?
Old Dec 2, 2008 | 12:11 PM
jksmith's Avatar
Default Difference in timing belts?
recently bought a fully assembled built block, basically everything brand new...but i dont know what kind of water pump it has on it, so i basically need to know if there is a difference between LS, GSR, B16 timing belts?
Old Dec 2, 2008 | 01:36 PM
boredracer408's Avatar
B16 timing belts are shorter than 1.8 belts because of the block height.
GSR and LS belts are different in length because the water pumps dont have the same number of teeth. If you have a vtec head i'd recommend a vtec water pump and timing belt.
Old Dec 4, 2008 | 01:59 PM
suno's Avatar
ITR and GSR timing belts are different from an LS because they have one more tooth on them.
Here are the part numbers...
B16 - 14400-P2T-004
LS - 14400-P7J-004
ITR - 14400-P72-014
GSR - 14400-P72-014
Hope this helps.
Old Dec 4, 2008 | 02:33 PM
SlowReaction's Avatar
Vtec waterpump should have 18 teeth and LS/B20 have 22 teeth.
B18B1-Crx
Jun 18, 2011 07:59 PM
young geezer
Jan 21, 2011 07:42 AM
B6tizzleHatch
14
Aug 14, 2006 08:49 PM
airwalk07143
Feb 7, 2005 03:17 PM
avividmemory
Jan 9, 2003 03:03 PM
