Dialing out overlap in cams
Old Mar 25, 2002 | 06:26 PM
It's Blue's Avatar
New User
Default Dialing out overlap in cams
How do I do this??? I need to dial out the overlap or as much as I can because I am using the NOS kit. Do I need to retard the exhaust and advance the intake? Advance the exhaust and retard the intake? Or is it the total opposite like retard both intake and exhaust or advancing both??? I need help soon guys, the races start this Saturday and I have the last appointment at the dyno on Friday. I am running a 125 shot on the NOS kit # 02040 and on the dyno I am only gaining 73 hp. I think that I am losing the other 50hp thru blow-by, because of both intake and exhaust valves being open at the same time.
Old Mar 25, 2002 | 07:49 PM
earl's Avatar
Default Re: Dialing out overlap in cams (It's Blue)
Advance the exhaust and retard the intake to cut overlap. Two or three degrees each at the most.This also has the affect of moving the valve away from the piston (which is good). Hope u have good valve springs, however
Old Mar 25, 2002 | 10:47 PM
Xerxes's Avatar
New User
Default Re: Dialing out overlap in cams (earl)
earl can you please explain the valve springs statement? I've considered getting cam gears to dial out overlap but haven't thought about valve springs at all...
-Xerxes
Old Mar 25, 2002 | 11:06 PM
earl's Avatar
Default Re: Dialing out overlap in cams (Xerxes)
Valves will float with stock springs when you start squeezing at high rpms. If that happens, you will bend valves. Better investment is good springs and titanium retainers than the cam gears.
Old Mar 26, 2002 | 12:54 AM
b18cTurbo's Avatar
earl there is one dyno in (integra dyno center)its a type r turbo that has dialing .50 advance on intake and .50 retard exaust ,do itr cams has a diff setup?im confuse on this
Old Mar 26, 2002 | 03:51 AM
turbotypeR@SPEC's Avatar
25 Year Member
Default Re: Dialing out overlap in cams (mikvtec)
i retarded my exhaust and advanced my intake and made 30 hp and about 15lbs of torque on the dyno.
Old Mar 26, 2002 | 06:43 AM
earl's Avatar
All set up react differently but the dyno doesn't lie. Just got to experiment but take baby steps until you're in control.
Old Mar 26, 2002 | 03:11 PM
Xerxes's Avatar
New User
ah okay cool, I thougth you meant that you want springs to go with the cam gears, i forgot that the other guy was talking about using nitrous
-Xerxes
Old Mar 26, 2002 | 04:20 PM
88CRXHybrid's Avatar
I believe blow-by is when oil leaks through the rings. Revision is where there is too much overlap and the partially burnt gases contaminate the intake tract.
fox297
Jul 17, 2003 08:13 PM
It's Blue
Mar 26, 2002 09:35 AM
It's Blue
Mar 26, 2002 07:04 AM
It's Blue
Mar 26, 2002 06:01 AM
