delay before engine cranks
Old May 18, 2003 | 02:04 AM
Vic Nyce's Avatar
Default delay before engine cranks
sometimes when i start my engine [95 C1 in a 95 DC4] it doesnt crank over right away. i turn the key to the start position and nothing. panic at first so i held it there and it cranked and started about 4 seconds later. very very unsettling. im scared im gonna get somewhere and not be able to start it at all. what can it be? whats also suspicious is that this doesnt happen all the time. sometimes it'll crank right when i turn the key.
Old May 18, 2003 | 04:43 AM
ryanstev's Avatar
Default Re: delay before engine cranks (Vic Nyce)
Does it click when you turn the key?
If so, there's dust in your solenoin, tap it with a screw driver and the dust will fall away.
Old May 18, 2003 | 07:43 AM
Chiovnidca's Avatar
Ignition switch maybe?
Old May 18, 2003 | 09:24 PM
Vic Nyce's Avatar
Default Re: delay before engine cranks (Chiovnidca)
no clicking....nothing....can it be my alarm maybe? it does have ignition cutoff. the system was disarmed tho. how do i check the ignition switch?
B16B Four Door
Sep 14, 2015 12:51 AM
raidacaipo
26
Aug 28, 2014 12:46 AM
IGuess
Nov 1, 2009 07:41 PM
StreetRiot_DRE
19
Jul 26, 2008 10:25 AM
