Koni sport upper assembly parts
Old Jul 8, 2004 | 09:10 PM
carbine's Avatar
Default Koni sport upper assembly parts
I just bought some koni sports second hand but the seller didn't give me alot of the parts
What im asking is can someone give me the measurements of some of the parts so i can make up some replacement pieces. Im not sure if they are the same on all koni yellows.
1) Washers, 2 for each shock
2) Plastic washers to go over the shock to prevent the bump stop sucking oil and ruining the shock, the washer allow air to move through.
3) Washers to go at the top, the lock nuts tighten over this.
4) Metal collars that replace to standard OEM ones.
So basically the items numbered 2, 3, 4 and 5 in this picture http://www.callum.orcon.net.nz/konifront.jpg
Thanks
btw these are shocks for ek hb
8041 1213SPORT and 8041 1152SPORT
Modified by carbine at 8:43 AM 7/9/2004
Old Jul 9, 2004 | 10:51 AM
carbine's Avatar
Default Re: Koni sport upper assembly parts (carbine)
ttt
Old Jul 10, 2004 | 11:59 AM
carbine's Avatar
last bump
Even just the thickness of the washers would do me and is the plastic washer a soft or hard plastic?
Old Jul 10, 2004 | 07:21 PM
99hatch's Avatar
All of the washers have pretty much the same diameter as your shock...they are maybe 2mm thick?
the plastic ones are not too hard but not that soft either
and the washer that goes on top of the upper mount is a bowl shaped one, when you put it on it keeps the lock nuts from going through the rubber pieces on the mount
and if you dont have the metal collars then idk where you are gonna get those from, they would be pretty hard to fabricate.
if you want me to get really specific let me know i just installed these on my car a few days ago..
mish__
Suspension & Brakes
Jul 9, 2010 10:51 PM
SoOHiGH
Suspension & Brakes
May 10, 2005 08:48 PM
etp72
Aug 15, 2004 10:16 AM
99ls
Dec 21, 2001 09:38 PM
