D16z6 Timing Issue?
Old Nov 4, 2009 | 04:35 PM
Phil_Civic's Avatar
Default D16z6 Timing Issue?
Hey everyone,
I've been searching around but can't seem to find the answer that fixes my problem.
I just rebuilt and replaced my cylinder head on my 93 Civic Si. I put in brand new valves and guides, all new seals and gaskets. The head was pressure tested, resurfaced, valve grind to reseat, and had the machine shop put the guides and everything on the head back together. Only thing I had to do was put the cam in and rocker arm assembly.
I've got the head back on now, but I can't get the car to start. There's spark, fuel and compression. I lined the mark on the balancer in TDC, and the mark on the cam with the mark on the timing cover back plate, and "up" facing up and slightly forward. The rotor in the dizzy is also facing the #1 cylinder, so I'm not 180 out, I don't think.
The engine comes close, but won't quite start, even when I move the timing belt over a tooth or two.
Any help or suggestions are appreciated.
Thanks,
Phil
Old Nov 5, 2009 | 10:21 AM
Phil_Civic's Avatar
Default Re: D16z6 Timing Issue?
Any ideas?
Old Nov 5, 2009 | 10:50 AM
delsolproblems's Avatar
If the TDC sensor is bad then the fuel could be injecting at the wrong time and you'd need a new distributor. Another problem that could cause this is if the pulleys on the balancer came loose from the center hub of the balancer. The marks on the cam gears should form a straight line that is level with the top of the upper timing cover.
Old Nov 5, 2009 | 03:16 PM
Phil_Civic's Avatar
The distributor was working well before I changed the head, could I have messed the sensor up during the swap? How do I go about testing the TDC sensor? There were no codes.
I'll have to take a second look at the balancer to make sure everything is tight.
Thanks for your help,
Phil
Old Nov 5, 2009 | 03:48 PM
1992Si's Avatar
You didn't mention adjusting the valves ?
Old Nov 5, 2009 | 03:52 PM
Phil_Civic's Avatar
Good call, I'll take a look at that.
Specs:
Exhaust: .009-.011"
Intake: .007-.009"
Is that right?
Thanks,
Phil
Old Nov 5, 2009 | 05:08 PM
1992Si's Avatar
Yes if I remember correctly.
Old Nov 6, 2009 | 07:30 AM
It's possible. With electrical equipment, even static from your clothes/body can damage parts sometimes. This is one reason to disconnect the neg battery terminal when you connect or disconnect electrical parts on the car. To check the TDC/CKP/CYP sensors you disconnect the wire bundle from the distributor connector and check the resistance across 3 pairs of wires. I'm not sure of the colors or resistance values for the D16z6 off the top of my head. I'm sure some nice fellow will post them for ya. A problem with one of those sensors will result in spark plugs wet with fuel.
Old Nov 6, 2009 | 07:40 AM
Oh, and be careful not to flood it while you work. As you probably know, liquids get angry when you try to compress them as much as gasses- they start breaking stuff.
Old Nov 6, 2009 | 07:43 AM
Specs:
Exhaust: .009-.011"
Intake: .007-.009"
Is that right?
Thanks,
Phil
That is correct.
Old Nov 6, 2009 | 10:30 AM
Phil_Civic's Avatar
That was it! They were way too tight since I put new valves in.
Thanks a lot,
Phil
LittlesilverEF
Dec 11, 2009 05:28 PM
CodyC142
15
May 30, 2007 12:18 PM
blackeg
10
Sep 1, 2003 08:54 AM
