d16y8 to d16y7 swap
Old Jul 14, 2016 | 06:09 PM
chevynova350's Avatar
Default d16y8 to d16y7 swap
i got a 99 civic ex d16y8 and it was knocking so buddys said get a y7 and swap thwm so i got a y7 block used my y8 head,intake,distributor,harness,computer,all the sensors,y8 timing belt cam gear water pump crank pully starts up wont rev past 5k so i unhook vtec put y7 computer in and it revs all the way now runs slugish so i checked timein it was 180 so i put it dead center amd wouldnt start at all so i put it back to 180 out and turned distributor to wear no holes lime up and used bolt amd washer to keep it from turning runs great now what could be my problem im not a honda guy
Old Jul 14, 2016 | 08:26 PM
Sharpie14l's Avatar
Default Re: d16y8 to d16y7 swap
Recheck the timing at the belt make sure it's in spec.
Old Jul 14, 2016 | 09:11 PM
K20A3F00L's Avatar
Wow, stressed out or some **** I guess but I read that as Redneck not recheck, lolz! In all seriousness, you should check the timing belt to make sure it is in spec
Old Jul 15, 2016 | 01:47 AM
it has the y8 timing belt in it thats what everyone said to use
xmd
Feb 4, 2019 07:01 AM
99civicman
Mar 6, 2009 04:41 PM
shifty162
Dec 13, 2008 12:36 PM
ppfalcon
10
Dec 18, 2005 06:59 PM
davken1102
16
Jan 10, 2004 09:24 AM
