d16 all motor
Old Aug 14, 2002 | 09:59 PM
oioioi's Avatar
Default d16 all motor
what kind of power is it possibale to get out of a d16z6 or d16y8 engine?
has anyone tried crower cams? what about higher compression pistons?
are intake manifold exchangable between D and B series motors?
and the final question, is the cankshaft-belt pulley bolt reverse threaded? (d16z6 94 ex)
thanks.
Old Aug 15, 2002 | 12:46 AM
D16Z6racing's Avatar
Default Re: d16 all motor (oioioi)
1) All motor, no juice or FI, I'd say 160-180hp.
2) Crower is great. I'd go with JE Pistons and rings IMO.
3) The intake manifolds are NOT interchangable. Venom makes a good IM for the D16.
4) Not sure on your pulley bolt. I wouldn't change the pulley anyways. Alternator pulley only. And that's not really worth it to me. I've done it.
[Modified by B18CX-EH, 1:47 AM 8/15/2002]
Old Aug 15, 2002 | 02:17 AM
kinesistech's Avatar
The crank pulley bolt is NOT reverse thread. Its normal righty tighty.
Old Aug 15, 2002 | 05:50 AM
oioioi's Avatar
what about throttle bodies between B and D series motors?
Old Aug 15, 2002 | 08:32 AM
Steve91's Avatar
That depends on how radiacal you are willing to go. If you had a JG 1.8L sleeved block, fully ported head with big cam, individual throttle bodies, and 14:1 compression, you would be over 200hp easily.
Old Aug 15, 2002 | 08:39 AM
Spade's Avatar
Swappable.....look for any of the B series or H series. 58mm (Measured by SGT)
or go with an even larger Type R witch is 62mm.
EX intake manifold is the best flowing of the D series. (Y8!!)
barfoeng
Jun 4, 2009 01:45 AM
jbs
Mar 25, 2004 12:25 PM
Austinbionic316
Feb 24, 2004 06:49 AM
Jeff 360
12
May 8, 2002 07:12 PM
