D15B7 swap to JDM D15B7 Help!
Old Dec 28, 2007 | 05:24 PM
vodman12's Avatar
Default D15B7 swap to JDM D15B7 Help!
Back ground -
This is a 1993 Civic DX, swapped my daughters blown motor for JDM of same type. Actual phyiscal swap went fine, but I think I have a timing problem. Even though I have used the wooden dowel method and found TDC and the Distributor looks as it is pointing at number one, the car idles very rough and lacks power.
When I try to move the distributor it has NO effect of the idle of the motor. Which I think is very strange.
My friend used timing light, but is unsure of the timing.
Question – Is there anything else I need to change for the swap? This was a long block to long block swap; I used the same TBI, Intake and exhaust, MT from the previous motor.
No CEL's
Thanks in advance and Happy New Year!
Old Dec 31, 2007 | 12:12 PM
MeGotRoundEye's Avatar
Default Re: D15B7 swap to JDM D15B7 Help! (vodman12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vodman12 &raquo;</TD></TR><TR><TD CLASS="quote">Back ground -
No CEL's
when you say swapped in jdm d15b7.. do you mean d15b?
wantboost1
Nov 24, 2017 03:12 PM
92EG8
Jan 6, 2007 11:01 PM
no_one_
Dec 13, 2004 09:21 AM
brnyrdcmndo
Aug 18, 2004 04:54 PM
