D-Series cam questions....
Old Nov 11, 2003 | 12:24 PM
Rydaddy's Avatar
Default D-Series cam questions....
Im looking at 3 different cams to use in my D-series build. The motor will be a y8 block with LS rods and a6 pistons (about 11:1 compression), and a ported z6 head with Crower springs and skunk2 Ti retainers and a .020" mill.
Here are the cams Im checking out
<U>Crower Stage 2:</U> Duration @ .050" = 230/204 Gross Lift = 427/432
<U>Zex 59300:</U> Duration @ .050" = 220/216 Gross Lift = 455/430
<U>Exospeed SV909:</U> Duration @ .010" = 296/266 Gross Lift = 396/376
First question: How can I convert the Exospeed duration to reflect .050" instead of .010" to compare more accurately? What does .010" and .050" reflect a measurement of?
Second: How does lift play a role in power production....ie: is too much a bad thing?
Third: Which one looks to have the best specs for my setup? It looks like the Exospeed cam will produce the most power with that high of duration, but the peak of the powerband will be a lot higher than with the other 2. This is going to be a daily driver, so i want to produce good power in the useable RPM band (2500-7000ish).
Thoughts, ideas? Thanks......
Old Nov 11, 2003 | 02:00 PM
Rydaddy's Avatar
Default Re: D-Series cam questions.... (Rydaddy)
I know it requires some thinking, but cmon!!!
Old Nov 11, 2003 | 02:51 PM
Rydaddy's Avatar
Up...
Old Nov 11, 2003 | 04:48 PM
Rydaddy's Avatar
Bump
Old Nov 11, 2003 | 11:09 PM
Rydaddy's Avatar
bump before bed....
Old Nov 12, 2003 | 09:06 AM
EG-lowrider's Avatar
did you search?
Z6-EX
Jan 21, 2007 02:31 AM
tommy.
May 11, 2006 08:49 AM
Superdragr45
Jan 25, 2005 07:52 AM
civicnar
Feb 24, 2004 09:52 AM
Rydaddy
Jun 24, 2003 02:43 PM
