Cylinder walls messed up. Any info how?
Old 12-14-2006, 09:43 AM
si937's Avatar
Default Cylinder walls messed up. Any info how?
Motor: D16y7
Miles: 173,000
I believe the motor has never gone through a head gasket until now. What cause this? Will it be safe to boost 8 psi?
thanks
Modified by si937 at 3:58 PM 12/14/2006
Old 12-14-2006, 10:24 AM
ekb16's Avatar
bubbles in ur coolant system
Old 12-14-2006, 10:44 AM
si937's Avatar
would eat away like that? Not the white stuff. thanks for da info
Old 12-14-2006, 12:30 PM
Super Chicken's Avatar
Default Re: Cylinder walls messed up. Any info how? (si937)
1st I wouldn't boost that engine unless you want to run it till it blows!
2nd It looks like maybe muratic acid somehow got into your cooling system or acids formed when your head gasket blew? Muratic acid melts aluminum easily and is the same stuff they use to balance pools PH. Maybe someone mixed some in with some coolant by mistake? IDK just guessing
Old 12-14-2006, 12:35 PM
BuddhaSiR's Avatar
Default Re: Cylinder walls messed up. Any info how? (Super Chicken)
boosting would not be a good idea. the cylinder walls are going to be very weak. i just seen something like that on a water pump on a dodge van. Not exactly sure what causes it though.
Old 12-14-2006, 01:57 PM
si937's Avatar
thanks alot guys. ya i buy the car from cali and i have always had a problem with the cooling system. would it be ok to run a new headgasket and headstuds or should i start looking for another one motor? there is a piece missing that is pretty close to the inside wall. thanks again
Old 12-14-2006, 02:15 PM
Hondaen's Avatar
This can be caused by several things.
1. Lack of proper coolant mixture. The mixture wil lower the freezing point and protect against galvanic corrosion like in the pictures.
2. Use of poluted water. The coolant water must be destilated or de-ionized. If not, elements in the water will cause oksidation of the cylinderwalls and other parts like in the pictures or make calsium deposits if the water has a high % of calsium.
If the water is in the acid state and there is no coolant like glycol, the acid will transfer electrons between the differens metals that the engine is made of. The metal with the lowest voltage will be "eaten" up and end up like oxide (white stuff you see on the pictures). Building a motor with the same metals/alloys is almost impossible. That means that galvanic corrosion will occour, and it is therefore very important to use proper coolant mixture with 100% clean water.
3. Cavitation of water due to high flowing water currents.
My opinion, use a good block for a turbo build. If the block blows, you will loose time and money. Blocks is rather cheap in the US, so why go for less.. The pictures show destroyed gasket seal area. Not the best when increasing the combusion pressure..
Sorry for my bad english :-|
Old 12-14-2006, 02:23 PM
si937's Avatar
Default Re: (Hondaen)
Naw man your fine. Ya when i bought the car i notice in some spots were getting eatin away. must of been the people i bought it from before. cool ill put it back together and just leave it stock. thanks for all the help.
Old 12-16-2006, 07:05 PM
blackeg's Avatar
Default Re: (si937)
****, ive never really seen that before, makes me nervous because i use tap water or poland spring to mix with my coolant...
i wouldnt boost that block...
Old 12-16-2006, 09:22 PM
si937's Avatar
ya man it sucks. i bought all this stuff wanting to boost and now i cant.
LstCivic
09-06-2010 09:15 AM
chatman_55
10-10-2009 09:30 PM
flash69
04-27-2009 01:36 PM
italianaccord
01-23-2006 10:57 PM
vtec.dc2
12
11-30-2004 03:31 PM
Quick Reply: Cylinder walls messed up. Any info how?
