cylinder missfire, code 72
Old Apr 8, 2009 | 06:22 AM
damgon's Avatar
Default cylinder missfire, code 72
I have a 97 accord wagon, it’s given me a code 72 missfire, and I have change the cap, rotor, wires and sparkplugs twice. I reset the ecu and wipe the codes and it will go a way for 3 months and then its back. So I rebuilt the head change the rings, cleaned the EGR and I change again wire cap rotor and sparkplugs, there was no code for 2 months and its back! And this time it will not go away. Please I need some help. Thanks.
Old Apr 8, 2009 | 09:19 AM
dtapia's Avatar
Default Re: cylinder missfire, code 72
where did you get that code ? normal dtc are p ---- codes
Old Apr 8, 2009 | 10:11 AM
damgon's Avatar
i got it from the diagnostic blue plug, and counting the (blinks)
Old Apr 8, 2009 | 04:36 PM
dtapia's Avatar
dtc 72 is a cylinder miss fire. AKA as p0302
cylinder # 3 miss fire or a fuel trim issue lots of reasons it coded up for it.
you need to have it looked at by some one with a advanced scanner or take it to honda so the data list can be viewed to see whats going on.
Old Apr 9, 2009 | 06:21 AM
damgon's Avatar
I will take it to a Honda dealer, but my friend has a 2001 accord ex and it has the same problem, he did the same tune-up I did (wires, cap, rotor and sparkplugs) he was able to rest it but it came back in 2 weeks. So he took it to the dealer and they ask him if he had Honda parts (OEM) on the car, he said no, that’s your problem! He spent close to$300 for the tune-up at the dealer, was rest and a month it came back. He did not want to take it back to the dealer because they rip him off. He still has the problem.
I have the identical car, I have 2, accords wagon 97, running, and I will like to try some thing, anything but I do not want to start taking the whole car apart. Were I can start testing, the ECU or distributor ext…thanks.
Old Apr 9, 2009 | 08:28 AM
dtapia's Avatar
make sure you ask for a print out of the data list and post your results so we can see what the car is doing.
a known fact that some after market plugs dont run well in hondas period.
Old Apr 9, 2009 | 10:01 AM
damgon's Avatar
will do. thanks
Old Apr 9, 2009 | 10:05 AM
damgon's Avatar
Keep in mind that the plugs are NGK ZFR5F-11.
Old Apr 9, 2009 | 05:25 PM
KWayRacing's Avatar
Possible Causes
#2 Fuel injector clogging, fuel leakage, air leakage
#2Fuel injector circuit open or shorted
Injector resistor malfunction
Distributor malfunction
Compression low
Valve clearance out of specification
EL Vap133
37
May 3, 2024 01:13 PM
eatbieodie2
Oct 22, 2005 08:16 PM
VTC_CiViC
Feb 25, 2005 11:34 AM
rukawa1one
Feb 15, 2005 05:53 PM
revvin9k
Nov 8, 2004 04:25 AM
