DIY-External distributor
Old Apr 8, 2009 | 07:02 AM
jazmie's Avatar
Default DIY-External distributor
as we well know that B16 engine this distributor easy to die......some solution that i knew modify the standard distributor become external distributor.....what i mean that the coil inside distributor put outside.......
anybody know n 1 2 share with us how to make it?....if with pic more better to understand
tq all bro
Old Apr 8, 2009 | 05:34 PM
fcm's Avatar
fcm
Old Fart
Default Re: DIY-External distributor
Easy as pie, one of these... http://www.msdignition.com/products/...ompact_import/
One of these... http://www.msdignition.com/products/coils/
One of these... http://www.msdignition.com/Products/...l_Bracket.aspx
A spark plug wire set, rotor and ballast and your done, very little wiring.
Check you local MSD dealer, they can probably put together a complete kit of all the pieces you need. 94
Old Apr 8, 2009 | 06:41 PM
srmofo's Avatar
that still may not fix your problem. Ignitors and the ckp/cyp also go bad...just as often as the coils....its important to find your problem first or you may be fixing something that isnt broke
Old Apr 9, 2009 | 05:57 AM
jazmie's Avatar
do u have the wiring diagram@picture?....tq bro
Old Apr 9, 2009 | 06:24 AM
fcm's Avatar
fcm
Old Fart
You will get a wiring diagram, [one wire] with the kit.94
Old Apr 9, 2009 | 07:24 AM
jazmie's Avatar
if i modify standard distributor and make it external distributor can rite?....i mean no need buy aftermarket like MSD
Old Apr 9, 2009 | 10:49 AM
fcm's Avatar
fcm
Old Fart
All you need is the distributor cap, not the whole distributor.
I have seen guys mod the stock cap so they can use an external coil but it has never worked very well, or for long.94
Old Apr 9, 2009 | 05:53 PM
jazmie's Avatar
that what i mean....i saw it b4......how to do it bro?....u got diagrag@any instruction?
its ok ....i think better than normal stock....if 1 2 more longer change the stock coil with aftermarket 1
DRAGANDB1
Aug 9, 2018 06:19 PM
Street_sleeper
Oct 15, 2011 05:47 PM
thunderboy
Jan 7, 2008 05:51 AM
ILuvMyJdmDc4
Nov 27, 2007 04:43 AM
