cutting bumpstops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pro1342 »</TD></TR><TR><TD CLASS="quote">That works too, but it's a pretty hard hit if the suspension bottoms out.</TD></TR></TABLE>
maybe he took the bumpstops and the springs out...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pro1342 »</TD></TR><TR><TD CLASS="quote">Cut in half with a razor blade....</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LillDragun »</TD></TR><TR><TD CLASS="quote">so just a razor? it isn't tough to cut is it?</TD></TR></TABLE>
a little more difficult than cutting a styrofoam cup. just be patient w/razor blade...
You dont have to cut them at all unless you go below 2". Although I cut like the first two ribs off to drop mine 1.5-1.75. You can cut them with a sharp pocket knife or a razor. A heavy duty box cutter would be ideal. Don't cut your arm off!
welli didn't realize i need to cut them off untill after the installation and i saw the instructions for the springs and they said to trip off 30 mm.
damn that was easy!!!.....the hardest part was getting my shock/spring assembly off the car.....i used a onesided razor and like ya'll said.....it's just a lill tougher than a styrofoam cup!
jaxx4k
Mar 21, 2005 04:54 PM
