CTR pistons in oversize, Help?
Old Dec 30, 2003 | 06:10 AM
94B18B1Teg's Avatar
Default CTR pistons in oversize, Help?
I'm going to bore my LS block but what size are the over sized CTR pistons? I think I would bore my block to 84MM. just wonderin what size is OS pistons are. Thanks.
Old Dec 30, 2003 | 06:14 AM
b19coupe's Avatar
Default Re: CTR pistons in oversize, Help? (94B18B1Teg)
Oversize CTR pistons are 81.25mm. Stock bore is 81.00mm.
Old Dec 30, 2003 | 02:08 PM
bigTom's Avatar
Default Re: CTR pistons in oversize, Help? (b19coupe)
actually its 25 thousandths or just a bit over 81.5mm
1mm=just under .040
os oem pistons call for a bore of 3.214"
Old Dec 30, 2003 | 02:36 PM
Kendall's Avatar
Contact CP Pistons, they can make you a set of pistons very similar to the CTR pistons in an 84 mm bore, or any other bore if you like. Just thought I'd let you know.
Old Dec 30, 2003 | 04:35 PM
b19coupe's Avatar
Default Re: CTR pistons in oversize, Help? (ek9t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9t &raquo;</TD></TR><TR><TD CLASS="quote">actually its 25 thousandths or just a bit over 81.5mm
1mm=just under .040
os oem pistons call for a bore of 3.214"</TD></TR></TABLE>
I do not know where this information is coming from. I work at an Acura dealer; OEM oversize pistons are 0.25 mm over, not 0.025"over. Look it up or call your local dealer to confirm.
LSvtechatch97
Apr 17, 2005 12:47 AM
my_little_beast
10
Jan 13, 2005 07:10 PM
94B18B1Teg
Jan 5, 2004 04:13 AM
juicedricer
Apr 11, 2003 01:34 PM
2k1 GSR
Feb 3, 2003 09:59 PM
