ctr pistons in B17
Old Jan 3, 2007 | 05:49 PM
Jago's Avatar
Default ctr pistons in B17
Just wondering if CTR pistons will work in a B17 GSR motor.
thanks
Old Jan 3, 2007 | 05:59 PM
Brick Top's Avatar
Default Re: ctr pistons in B17 (Jago)
yes
Old Jan 3, 2007 | 06:51 PM
FIGARILA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jago &raquo;</TD></TR><TR><TD CLASS="quote">Just wondering if CTR pistons will work in a B17 GSR motor.
thanks</TD></TR></TABLE>
thats a whole lot of commpression.
Old Jan 3, 2007 | 07:30 PM
EJgsr's Avatar
Default Re: ctr pistons in B17 (F I G A R I L A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by F I G A R I L A &raquo;</TD></TR><TR><TD CLASS="quote">
thats a whole lot of commpression.</TD></TR></TABLE>
Old Jan 3, 2007 | 07:40 PM
Jago's Avatar
Default Re: ctr pistons in B17 (USDMej1)
What would the compression ratio be?
Old Jan 3, 2007 | 08:06 PM
EJgsr's Avatar
12.47 with using stock everything with just pistons...
Old Jan 4, 2007 | 10:02 AM
Jakester9500's Avatar
you better not be putting regular gas in that baby
Old Jan 4, 2007 | 03:14 PM
Jago's Avatar
Default Re: (Jakester9500)
is there any rod you can use with them to lower the compression ratio a little. Im asking for a friend of mine
Old Jan 4, 2007 | 08:39 PM
FIGARILA's Avatar
Default Re: (Jago)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jago &raquo;</TD></TR><TR><TD CLASS="quote">is there any rod you can use with them to lower the compression ratio a little. Im asking for a friend of mine</TD></TR></TABLE>
not any b-series, the p61 rod is the shortest at 132mm length, a b16 rod is like 134mm. Why don't you run some p30's or some USDM p73.
Old Jan 4, 2007 | 09:21 PM
PHDZINE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMej1 &raquo;</TD></TR><TR><TD CLASS="quote">12.47 with using stock everything with just pistons... </TD></TR></TABLE>
Thats wrong! The compression will be exactly what a CTR is.The B17 has a PR3 head.
Old Jan 5, 2007 | 06:45 AM
mmuller's Avatar
Mad Scientist
Default Re: ctr pistons in B17 (PHDZINE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHDZINE &raquo;</TD></TR><TR><TD CLASS="quote">Thats wrong! The compression will be exactly what a CTR is.The B17 has a PR3 head.</TD></TR></TABLE>
not true, b16b uses a b18 block wich has a taller deck height than the b16a/b17.
pct pistons stick out of the deck because of compression height
Old Jan 5, 2007 | 11:07 AM
EJgsr's Avatar
o really???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">
pct pistons stick out of the deck because of compression height</TD></TR></TABLE>
thank you.
Old Jan 7, 2007 | 03:26 PM
Jago's Avatar
Default Re: (F I G A R I L A)
not any b-series, the p61 rod is the shortest at 132mm length, a b16 rod is like 134mm. Why don't you run some p30's or some USDM p73.</TD></TR></TABLE>
what would the compression be with that combination. Is there any other better options
Old Jan 8, 2007 | 06:18 PM
PHDZINE's Avatar
Default Re: ctr pistons in B17 (mmuller)
True...the B16b uses the B18C block which is 212.39mm if thats the B-series your talking about. The PCT (B16B) compression dome sticks out of the block and not the piston itself. IT doesn't matter that the B16B uses the B18C block with the taller deck height because it's offset with a shorter stroke (77.40mm vs 87.20mm B18c) and longer rod (142.3mm vs 137.9mm B18c).
My bad for saying thats wrong before I researched everything...this is true or very very close.
Old Jan 8, 2007 | 06:50 PM
mmuller's Avatar
Mad Scientist
PCt's on a b16a block will stick out of the hole, and i mean besides the dome. pr3/p30 pistons have a different compression height than pct's; PCT's Using the same rod PCT's will sit .03'' higher in the bore than pr3/p30's; on a b16a block thats .01 out
Old Jan 8, 2007 | 09:36 PM
PHDZINE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">PCt's on a b16a block will stick out of the hole, and i mean besides the dome. pr3/p30 pistons have a different compression height than pct's; PCT's Using the same rod PCT's will sit .03'' higher in the bore than pr3/p30's; on a b16a block thats .01 out</TD></TR></TABLE>
94typeR
May 26, 2007 11:59 AM
hytec
Apr 13, 2006 12:57 PM
dayaftertomorrow
Jan 23, 2006 12:20 AM
TypeR II
Jul 22, 2004 08:19 PM
MR. MIYAGI
10
Apr 28, 2004 06:53 PM
