CTR pistons?
Old May 23, 2007 | 01:59 AM
94typeR's Avatar
Default CTR pistons?
is there anything i have to watch out for if i decide to put CTR spec pistons in my jdm itr motor? will the compression be too high with a stock headgasket?
Old May 23, 2007 | 03:58 AM
neo_'s Avatar
Default Re: CTR pistons? (94typeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94typeR &raquo;</TD></TR><TR><TD CLASS="quote">is there anything i have to watch out for if i decide to put CTR spec pistons in my jdm itr motor? </TD></TR></TABLE>
Detonation
will the compression be too high with a stock headgasket?</TD></TR></TABLE>
No
Old May 23, 2007 | 04:59 AM
GO-FIGHT-KILL's Avatar
Kaboom Kaboom.
Old May 23, 2007 | 07:48 AM
Rollo Lawson's Avatar
Default Re: CTR pistons? (neo_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo_ &raquo;</TD></TR><TR><TD CLASS="quote">No</TD></TR></TABLE>
what? with the oem h/g, his c.r. will be in the 13+/1 area. you've been warned..........
Old May 23, 2007 | 07:50 AM
itr1244's Avatar
Default Re: CTR pistons? (Rollo Lawson)
running ctr in my B18c5 for a year now.
with cams and blah blah.
clay'd the piston and there's ENOUGH valve to piston clearance.
and had no problems yet . sooooo..
and the c/r would be 12.5 ish
Old May 23, 2007 | 05:52 PM
neo_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rollo Lawson &raquo;</TD></TR><TR><TD CLASS="quote">
what? with the oem h/g, his c.r. will be in the 13+/1 area. you've been warned..........</TD></TR></TABLE>
I have been running CTR pistons in my Type R for over 2 years now. With close to 30,000 miles on an OEM head gasket with zero problems. I know people that put down 500 WHP on boost with OEM head gaskets.
Old May 23, 2007 | 06:40 PM
crawlin's Avatar
im running ctr's in my ls/vtec running strong for 15,000 miles plus. comp is slightly over 13-1 with a gsr head.
Old May 23, 2007 | 07:02 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: CTR pistons? (crawlin)
my ctr piston'd r is running strong as hell and no signs of detonation... its all in the tuning, plus a bigger cam will bleed off enough compression anyways
Old May 26, 2007 | 09:15 AM
azrakain's Avatar
Has anyone actually measured for compression with this setup? When I use the c-speed engine builder it spits out 11.75:1 as the compression. That is staying all OEM parts (b18c5).
Old May 26, 2007 | 09:26 AM
neo_'s Avatar
Default Re: (azrakain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azrakain &raquo;</TD></TR><TR><TD CLASS="quote">Has anyone actually measured for compression with this setup? When I use the c-speed engine builder it spits out 11.75:1 as the compression. That is staying all OEM parts (b18c5).</TD></TR></TABLE>
There was a huge 30 page thread about exactly this in the All Motor forum. I believe the final number was 12.8:1 or something along those lines.
Old May 26, 2007 | 10:46 AM
azrakain's Avatar
Default Re: (neo_)
There was a huge 30 page thread about exactly this in the All Motor forum. I believe the final number was 12.8:1 or something along those lines.</TD></TR></TABLE>
I guess I'll have to go look for that. Finding something with PCT or CTR in the All Motor forum should pose to be a chore. LOL
Old May 26, 2007 | 11:10 AM
itr1244's Avatar
ya.. really tho. how can you "measure" the compression ratio?
is there a tool for that?
i dont see how this could be done
Old May 26, 2007 | 11:59 AM
azrakain's Avatar
Default Re: (itr1244)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 &raquo;</TD></TR><TR><TD CLASS="quote">ya.. really tho. how can you "measure" the compression ratio?
i dont see how this could be done</TD></TR></TABLE>
Here is a good article.
http://www.chevyhiperformance....guide/
weaksoN!
Feb 28, 2008 02:54 PM
Jago
Jan 8, 2007 09:36 PM
hytec
Apr 13, 2006 12:57 PM
pacifico
29
Mar 18, 2005 11:59 AM
TypeR II
Jul 22, 2004 08:19 PM
