which piston should I pick
Old Jan 22, 2006 | 09:25 PM
dayaftertomorrow's Avatar
Default which piston should I pick
I am consider picking up a set of piston for gsr. Which one should I pick? JDM civic type R or integra type R? WHich is better? tks
Old Jan 22, 2006 | 10:28 PM
Ruben19's Avatar
go with ctr pistons
higher compression
it makes 10:8.1 in a b16b and with a gsr head will probably go 11:1
itr on a gsr around 10:6.1 or a lil more.
defenetly ctr pistons they r better
Old Jan 22, 2006 | 10:33 PM
..::91TEG-G2::..'s Avatar
Default Re: (Ruben19)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ruben19 &raquo;</TD></TR><TR><TD CLASS="quote">go with ctr pistons
higher compression
defenetly ctr pistons they r better</TD></TR></TABLE>
you mean 10.8:1 and 10.6:1?
ten point eight TO one ratio...
ten point six TO one ratio
Old Jan 22, 2006 | 11:38 PM
So higher compression means more horse power? Also what is the red line if I change to ctr pistions
Old Jan 23, 2006 | 12:20 AM
iH8RICERZ's Avatar
Default Re: (dayaftertomorrow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dayaftertomorrow &raquo;</TD></TR><TR><TD CLASS="quote">So higher compression means more horse power? Also what is the red line if I change to ctr pistions</TD></TR></TABLE>
rev limit depends on what type of valve train you have...also if your cams make the power at high rpm's. but yes, higher compression with agressive cams= BIG POWER!
I actually happen to have a set of brand new oem ctr standard bore pistons/rings/wrist pins for sale PM me if your interested
dev
Jan 27, 2007 08:38 AM
Jago
Jan 8, 2007 09:36 PM
jeremy.
199
Dec 23, 2004 03:45 PM
ek9dc2
Oct 13, 2003 08:12 PM
duRritztiNy
35
May 16, 2003 10:36 PM
