ctr/itr? rpm
hey guys i just got a set of itr cams on my gsr motor, an i put the dual valve intake springs on the exhuast side, how well will my car run, can i rev to 9k? will i notice a difference? lmk thanks
unless your motor is fully built or your head has a damn good *** PnP work done why do you want to rev to 9k for? if you want your valves to bend or **** to break then take off ur revlimiter and take it to 9k
buddy of mine put itr cams in his gsr and it didn't make a diff. pass 8500 but if you did the head right (correction) w/ or w/o pnp 9k isn't gonna bend valves... my b16a in my 90' rex redlines at 10200 rpms, and im pushing to make it go higher and thats with mild head work and bottom end work. but its up too you totaly but aslong as your valves and springs are good and the cams wernt scratched youll be good going up to 9krpms. in my mind anywayz FTW
itr/ctr cams arent going to make power above 8200-8500. most people rev higher so when they shift they fall back into the powerband.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slprhndaboii88 »</TD></TR><TR><TD CLASS="quote">buddy of mine put itr cams in his gsr and it didn't make a diff. pass 8500 but if you did the head right (correction) w/ or w/o pnp 9k isn't gonna bend valves... my b16a in my 90' rex redlines at 10200 rpms, and im pushing to make it go higher and thats with mild head work and bottom end work. but its up too you totaly but aslong as your valves and springs are good and the cams wernt scratched youll be good going up to 9krpms. in my mind anywayz FTW</TD></TR></TABLE>
what cams and valvetrain are you using for those idiotic rpm's?
Ryan C
11
Nov 25, 2003 06:35 PM
