H22 Rebuild
Old Apr 29, 2007 | 08:38 AM
hybrid2007's Avatar
Default H22 Rebuild
I've got an EG H/B with a JDM H22 lump in which im getting ready to go back on the road but my crank seals have gone so i'm getting the engine out this weekend. While the engine is out i may aswell go through the whole engine and make sure everything is ok and also was thinking about swapping in a set of type s pistons or aftermarket of the same compression ratio. This will be the first major work i've ever done so i have a few questions.
Should i change the main and rod bearings while im there?
If i did swap out the pistons will everything run ok with the stock ecu or would i need to get it mapped?
Are Nippon pistons any good and would i be able to use them with stock rods?
This is quite a daunting task to me so any help you could give would be greatly appreciated
Modified by hybrid2007 at 11:18 AM 4/29/2007
Old Apr 29, 2007 | 06:18 PM
fast forward driver's Avatar
Default Re: H22 Rebuild (hybrid2007)
h series engines require sleeves before pistons can be installed
Old Apr 29, 2007 | 09:35 PM
doood's Avatar
been there done that
Default Re: H22 Rebuild (fast forward driver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast forward driver &raquo;</TD></TR><TR><TD CLASS="quote">h series engines require sleeves before pistons can be installed</TD></TR></TABLE>
unless you use type s or mahle gold series pistons
Old Apr 30, 2007 | 08:26 AM
hybrid2007's Avatar
Ok thanks, looks like i'll be going for type s pistons unless my bore is in a poor shape when i strip it.
With the slightly higher compression will i need a bit of RR time do get it running to its full potential?
TuneAccordingly
Jun 8, 2012 08:28 PM
jaron001
Jun 5, 2012 02:36 PM
xkrazyxjbrkerx75
Nov 26, 2009 04:45 PM
quickchris
Jun 17, 2005 07:15 AM
Ri5e
Sep 25, 2003 02:01 AM
