CTR- B20 block (n/a)
Old Oct 3, 2007 | 11:37 AM
nitewolf's Avatar
Default CTR- B20 block (n/a)
when i get mi blocc sleeved should i use CTR pistons and what bore/brand of sleeves should i get
thanks in advance
Old Oct 3, 2007 | 06:15 PM
boostinCX's Avatar
Default Re: CTR- B20 block (nitewolf)
If you are sleeving your block, what would be your reasons for sticking with the stock bore? You are already dishing out the dough for sleeves, pistons and labor, why not go larger bore like 84mm? Its all preference, if you just want a high cr piston like a ctr then there is no need to resleeve just get the oversized pistons and machine your block to match. Hope i helped, anyone else have advice for this guy..
Old Oct 3, 2007 | 07:46 PM
doood's Avatar
been there done that
tell me how you plan to fit 81mm pistons (ctr) into an 84mm bore (b20)?
Old Oct 3, 2007 | 11:44 PM
boostinCX's Avatar
Default Re: CTR- B20 block (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">tell me how you plan to fit 81mm pistons (ctr) into an 84mm bore (b20)?</TD></TR></TABLE>
If your talking to me i meant if he is sleeving why not go 84mm sleeves and get 84mm pistons too. Im fully aware of the factory bore size for ctr/itr pistons.
Old Oct 3, 2007 | 11:50 PM
doood's Avatar
Default Re: CTR- B20 block (boostinCX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostinCX &raquo;</TD></TR><TR><TD CLASS="quote">If your talking to me i meant if he is sleeving why not go 84mm sleeves and get 84mm pistons too. Im fully aware of the factory bore size for ctr/itr pistons.</TD></TR></TABLE>
i was talking to him
Old Oct 4, 2007 | 09:51 AM
formby's Avatar
http://cgi.ebay.com/ebaymotors...ZWDVW
these are 84mm integra r replica pistons by RS machine
hope it helps
manoloek9
13
Aug 8, 2010 06:36 PM
kidd_drastic
Nov 11, 2005 12:39 PM
94B18B1Teg
Jan 5, 2004 04:13 AM
SLEPTONEG6
Dec 22, 2003 12:10 PM
willyboyK20
Apr 16, 2002 10:23 AM
