HAVE A PROBLEM WITH A 90 DA
Old Jul 8, 2004 | 09:39 AM
19da90's Avatar
Default HAVE A PROBLEM WITH A 90 DA
When i was on my way to work today, my car battery light was on, i was like thats funny, but then i started to drive, it was blinking and then the car started to die when i gased it. does anyone know what could be wrong?
Old Jul 8, 2004 | 09:40 AM
Slo Car's Avatar
Default Re: HAVE A PROBLEM WITH A 90 DA (19da90)
most likely alternator....did it die completely?
Old Jul 8, 2004 | 09:47 AM
19da90's Avatar
Default Re: HAVE A PROBLEM WITH A 90 DA (Slo Car)
no i turned off my light and it stoped
Old Jul 8, 2004 | 09:48 AM
19da90's Avatar
i was thinking it was the alternator
Old Jul 8, 2004 | 10:14 AM
Colin's Avatar
Check all your battery and alternator connections to make sure they are tight and clean. Then check the battery and alternator with a multimeter. You should get ~12v across the terminals when the car is off, and ~14v when the car is on.
Old Jul 8, 2004 | 10:46 AM
19da90's Avatar
Default Re: HAVE A PROBLEM WITH A 90 DA (91IntegGS)
ok thanks
Old Jul 8, 2004 | 11:13 AM
jkeno112's Avatar
that is a straight alternator problem. had to change my alternator twice on my da. Same symptoms you are having is what i went through. New Alternator!!!!
Old Jul 8, 2004 | 11:20 AM
FR-MOB: ThE bEe GuY's Avatar
Default Re: HAVE A PROBLEM WITH A 90 DA (jkeno112)
Yup Sounds like alternator. The car slowly dies because when the alternator dies, the car draws power directly from the battery, then when the battry slowly dies so does the car. Had that **** happen in my CRX 3 friggin times
Old Jul 8, 2004 | 11:36 AM
HON-da's Avatar
Default Re: HAVE A PROBLEM WITH A 90 DA (ThE bEe GuY)
TUCHEI
Spencerk10
Sep 13, 2015 08:48 PM
hondastrtracr
16
Jan 27, 2008 09:16 PM
fwdftw
Aug 1, 2006 05:43 PM
deeice30
Dec 13, 2005 11:37 AM
