Crome Installion....Things needed
Old Feb 24, 2006 | 10:34 PM
JDMkidGSR's Avatar
Default Crome Installion....Things needed
OK I downloaded CROME.....but the thing is that I dont know where to buy the connections to connect the PC with the ECU....Any good websites I can get it from...Anyways thanks for the help.
Old Feb 24, 2006 | 10:58 PM
2SlowDC's Avatar
Default Re: Crome Installion....Things needed (JDMkidGSR)
i want to know to
Old Feb 25, 2006 | 05:23 AM
v4lu3s's Avatar
RTFM
read http://www.pgmfi.org
Old Feb 25, 2006 | 05:32 AM
mmuller's Avatar
Mad Scientist
what, your looking for real time programming stuff or rs 232/ usb stuff?
moates.net
and as above pgmfi.org
Old Feb 25, 2006 | 12:25 PM
96dc2's Avatar
Is your ECU chipped yet? You need to add a 4-pin header to the ECU to datalog. Then you use a special cable to connect it to your laptop. Do you already have a burner and/or emulator?
Old Feb 25, 2006 | 04:35 PM
JDMkidGSR's Avatar
Default Re: Crome Installion....Things needed (96dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96dc2 &raquo;</TD></TR><TR><TD CLASS="quote">Is your ECU chipped yet? You need to add a 4-pin header to the ECU to datalog. Then you use a special cable to connect it to your laptop. Do you already have a burner and/or emulator?</TD></TR></TABLE>
Where do I get the 4-pin header for the ecu, can i get it from the same company from above.
Old Feb 25, 2006 | 04:43 PM
96dc2's Avatar
Yeah you can get the parts from Moates.net, xenocron.com, phearable.net, etc. Or you can just send in your ECU to get it all done by them if you're not into soldering.
Old Feb 25, 2006 | 06:45 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMkidGSR &raquo;</TD></TR><TR><TD CLASS="quote">Where do I get the 4-pin header for the ecu, can i get it from the same company from above.</TD></TR></TABLE>
http://www.digikey.com
EG6 Love
Engine Management and Tuning
16
Oct 9, 2011 09:13 AM
See Are X
Dec 13, 2005 03:08 PM
rjay8604
Nov 19, 2005 06:36 AM
93civciv
Apr 7, 2005 07:40 AM
Vsm Hatch
Jan 26, 2005 07:08 PM
