need help finding this ecu part
Old Jan 26, 2005 | 12:33 AM
Vsm Hatch's Avatar
Default need help finding this ecu part
anyone know where i can find this part or what its called? thanks.
Old Jan 26, 2005 | 03:52 AM
mrx's Avatar
mrx
Default Re: need help finding this ecu part (LazyNip)
here in germany we call this a circoit-board-connector
costs about less then 1 euro
you should get it in nearly every electronic shop...
look that the pin distance is 2,5mm because they are also available in 2mm distance.
in germany you can buy them mostly together with the other side connector inkl. a short piece of cable mounted on it... but maybe you get one alone ...
hope to help
malte.
Old Jan 26, 2005 | 04:19 AM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LazyNip &raquo;</TD></TR><TR><TD CLASS="quote">anyone know where i can find this part or what its called?
thanks.</TD></TR></TABLE>
That's your ECU's CN2 connector. Well, it's actually not a connector, when you lok at a stock ECU the holes are soldered over. Are you thinking about setting up your ECU for datalogging or something? what EMS are you using? uberdata, hondata, crome?
check out the Keebler link in my sig and in his site, look at the link about datalogging.
Old Jan 26, 2005 | 06:45 AM
Boosted96EK's Avatar
Have an old mouse lying around... Crack that puppy open and desoldet the connector that goes from the board to your mouse cable and there you go... Thats what im doing...
Old Jan 26, 2005 | 06:49 AM
dennis's Avatar
You can pretty much use whatever. Like the others said, you probably have some junk electronics laying around you could scaveng.
I ordered some from:
http://www.futurlec.com/Connectors.shtml
Old Jan 26, 2005 | 07:08 PM
xenocron's Avatar
Default Re: need help finding this ecu part (dennis)
Digikey part #A1922-ND
Can be found in the Wiki @ PGMFI
wiki.pgmfi.org
mugencx
Sep 26, 2007 06:35 PM
Sir Crx
Jun 26, 2007 05:11 PM
r1ch1e
Nov 19, 2005 06:32 AM
phatrick2332
May 7, 2004 07:23 PM
