crank pully question
Old Aug 7, 2003 | 05:05 PM
SoCaLNaTIvE's Avatar
Default crank pully question
on a gsr crank pulley there are a total of four marks, first being a white notch second (about 1/4 inch down the pulley) a blank notch. past that another white notch followed by another blank notch. so which is used for top dead center?
thanks
Old Aug 7, 2003 | 05:15 PM
aeolus's Avatar
Default Re: crank pully question (SoCaLNaTIvE)
usually on most honda motors its the white mark.
Old Aug 7, 2003 | 05:26 PM
Dokta's Avatar
Default Re: crank pully question (aeolus)
the mark that's all by itself is tdc. The other mark that is between the two blank marks is stock timing (16 degrees i think).
Old Aug 7, 2003 | 06:23 PM
quik1's Avatar
Default Re: crank pully question (Dokta)
Red mark is 16 degrees, white mark TDC
Old Aug 7, 2003 | 07:13 PM
HONDADNA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aeolus &raquo;</TD></TR><TR><TD CLASS="quote">usually on most honda motors its the white mark.</TD></TR></TABLE>
it's all hondas - note most honda's. all hondas uses the white mark for DTC#1
Old Aug 8, 2003 | 11:21 PM
aeolus's Avatar
Default Re: crank pully question (HONDADNA)
what i meant by most hondas is sometimes the white mark can come off or fade to a beige or yellow color.
Old Aug 10, 2003 | 12:44 PM
HONDADNA's Avatar
okay...
circapunk
22
Aug 29, 2007 03:15 AM
xXx Justin xXx
11
Apr 16, 2004 02:34 PM
shingles
Mar 23, 2004 07:41 PM
pg_thao
May 14, 2003 10:21 AM
