crank pulley wobbling? help...
Old Sep 24, 2004 | 06:21 AM
TurboBumblBee's Avatar
Default crank pulley wobbling? help...
i noticed on a friends car that her oem b18c crank pulley looks as if its wobbling a little bit.. the timing belt was replaced about 10k miles ago.. it had a chip or 2 in it also and i think that might be whats causing it.. could this do any damage to the motor? the car drives fine and has no problems at all.. i think i might just find her a new one w/ out a chip in it put it on..
Old Sep 24, 2004 | 07:11 AM
opkjoblacsh's Avatar
Default Re: crank pulley wobbling? help... (TurboBumblBee)
i know nothing about this but im wondering how you have a 2.0 b18c1 ??
did you mean you have a b20b block with a b18c1 head on it sorry i cant be anyhelp but that just didnt make sense
Old Sep 24, 2004 | 09:53 AM
Default Re: crank pulley wobbling? help... (opkjoblacsh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opkjoblacsh &raquo;</TD></TR><TR><TD CLASS="quote">i know nothing about this but im wondering how you have a 2.0 b18c1 ??
did you mean you have a b20b block with a b18c1 head on it sorry i cant be anyhelp but that just didnt make sense</TD></TR></TABLE>
i have a b18c block that has been bored out to 84m and now the displacement equals a 2.0 liters
back to the top for some answers....
Old Sep 24, 2004 | 11:09 AM
Octoman's Avatar
Tell her to stop driving it NOW!!!!! If it comes off it can ruin the end of the crank where it is attached! Believe me, this same thing happened to my B16. The key way was torn up and the threads where the crank pulley bolt goes in were totally destroyed! Park that car and take a good look at it! Replace the pulley, the key and the bolt. Fix this before it gets worse!
Old Sep 24, 2004 | 12:03 PM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: crank pulley wobbling? help... (Octoman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Octoman &raquo;</TD></TR><TR><TD CLASS="quote"> Tell her to stop driving it NOW!!!!! If it comes off it can ruin the end of the crank where it is attached! Believe me, this same thing happened to my B16. The key way was torn up and the threads where the crank pulley bolt goes in were totally destroyed! Park that car and take a good look at it! Replace the pulley, the key and the bolt. Fix this before it gets worse!
Yep, stop driving it now. The wobbling pulley can also excite harmonics of the crank and destroy your oil pump, thus destroying the engine.
Old Sep 24, 2004 | 12:23 PM
stareatsun's Avatar
reasons why its wobbeling.
offbalance because of the chips in it
no tightened down enough so its loose.
crank bearing is crap
def stop driving the car and ge the thing looked at.
Old Sep 24, 2004 | 12:45 PM
Default Re: (stareatsun)
its not a lot of wobble.. just enough to see, almost looks like its off balance because of the chip...
anyone have a crank pulley i can buy from them??
Old Sep 24, 2004 | 09:20 PM
Default Re: (TurboBumblBee)
anybody??
i can get a new one from acrua for $170 w/ a new bolt or i can spend about $80 and get an N1 pulley for my car and sell mine to her but im not sure if want or need the n1 pulley...
Old Oct 5, 2004 | 04:32 AM
everyone take a look at this please...
https://honda-tech.com/zerothread?id=1003370
also if you dont feel like opening another thread here is a pic and video.. it looks fine to me after seeing it agian..
http://www.we-todd-did-racing....1NDE=
Old Oct 5, 2004 | 07:19 AM
mmuller's Avatar
Mad Scientist
i cant see anything on the video, but its easy...if it wobbles, change it
Old Oct 23, 2004 | 02:45 PM
krindus's Avatar
Default Re:
I've encountered near to the same problem, except mine has wobbled almost compeltely off. threw my belts, minus the alt belt, tried wrenching it on but it didn't work. we impacted it back on and that seemed to work fine, but the same problem happened again, Any ideas what it may be? do i just need to replace the bolt, pulley, and key or might it be something more or less?
matmcg
Jun 15, 2008 09:54 PM
Bense
Jul 6, 2007 11:54 AM
ultradx
Nov 14, 2005 01:42 PM
McDade
Oct 12, 2003 10:37 AM
pete332
Jul 24, 2003 12:44 AM
