Crank pulley "wobble"
Ok i have an 01 gsr STOCK new gates belt, new oem wp, and tensioner has 50k or so (putting new one on now). I have some wobble on the crank pulley ONLY. I have put straight edge on oil pump reluctor ring (best i could) and does not seem to wobble there. How would i have wobble just at the pulley itself? It mainly does at idle, rev a small bit seems to die down.
Anyone else had this issue?
*** dont know if worth noting
I do have an ls crank pulley on there w/ both belt guide rings (after i took off obd2 oil pump gear for obd1 ls). It was tq correctly with proper oem honda holding tool for crank.
You possibly have a pulley failing, the outter ring is coming loose and can potentially grind into the timing cover or worse; explode and blow through your hood etc.. You want to get a new ballancer on that fast if it has slipped. eBay has great deals on factory ones or you could go ATI $uper Damper.
Thats kinda what i fig wasthe rubber inner ring. I encounter "noise" with them being bad as a chevy tech. Will honda ones make "noise"? Alot of gm ones rattle or sound metallicy. Because i have also had a pretty odd whining noise. I fig was tbelt tentioner on its way out, part of reason i am changing in a few mins. I have a buddy local who has a few other ls/b20 crank pulleys so all good finding new one.
Sorry did not see your reply when i posted last post. I have an ls on there because my gsr lb did not come with one, was no big deal as i had one. As far as i know and have personally seen they are interchangeable. All my belts line up good (with belt laser), ac/alt
Was deff the balance pulley that was going bad. Put on another ls/b20 ans straight as an arrow. Now just got to get small alt belt, as new pulley is 1/2" in od small or so
mrowxlived
Sep 9, 2017 10:54 AM
maxxdout
Nov 13, 2002 12:52 PM
