Crank pulley balancing
Old Jan 31, 2003 | 05:51 PM
ChiBoy's Avatar
Default Crank pulley balancing
I have a crank pulley that has a couple of small chips in the outer 2 belt positions. I only need the alternator belt, so I was thinking about machining off some of the chipped material.
If I did it, how would/could/should I check the balance afterwards?
Old Jan 31, 2003 | 06:21 PM
BabyDaddy's Avatar
Default Re: Crank pulley balancing (ChiBoy)
If your motor is apart I'd say mount it on your crank and put it on a electronic harmonic balancer. If your gonna go to that trouble, go ahead and mount your flywheel and pressure plate to zero-out the whole assembly.
Old Jan 31, 2003 | 06:45 PM
ChiBoy's Avatar
Default Re: Crank pulley balancing (BabyDaddy)
But is there a way to balance the pulley alone? It looks like it is balanced from the factory because it has a balancing hole drilled in it.
Old Jan 31, 2003 | 08:10 PM
1SlowB16EF's Avatar
no you have to balance it with the crank
LOtownNateB's Avatar
Call PaynTechnologies ... they sell lighted and balanced stock crank pulleys
www.PaynTechnologies.com
bks84
Engine Machining & Assembly
Jun 29, 2015 01:51 PM
civikdude
Feb 13, 2009 02:17 PM
bow tie
Oct 17, 2008 01:18 PM
twistedbydezign
Sep 24, 2005 02:10 PM
asefi944
Apr 11, 2005 02:26 PM
