damaged crank snout
Old May 28, 2015 | 01:18 PM
bks84's Avatar
Loved
Default damaged crank snout
Im in the midst of doing a headgasket, timing belt etc job on a 96 Integra. I got the head off and machined, and upon removal of the crank pulley i found this... I had this on my own personal car as well, but was able to just put it back together w/a new key and pulley
Im curious if theres anything aside from replacing the crank/engine that can be done to save this.
Also, what causes this? Ive never had a crank pulley just come loose, but I have seen them wobble, which I assume is the rubber wearing out.
Old May 28, 2015 | 04:11 PM
PyroProblem's Avatar
Default Re: damaged crank snout
Yes. Crankshaft should be able to be repaired. I had a crankshaft damaged in a similar way from an aftermarket aluminum crank pulley. It rounded the keyway and the crank pulley would wobble like a ****. I found a local crankshaft repair shop in the Houston area and they repaired it. I can't remember what they charged but I think it was reasonable like maybe a hundred bucks or so.
Just make sure after they weld it that they don't cut it a 180 degrees out like they did mine. I had a helluva time trying to set base ignition timing lol.
Old May 28, 2015 | 07:45 PM
bks84's Avatar
Loved
I ended up sourcing a 4.5mm X 21mm key and pushed it in under the timing belt cog and it stuck out enough for the crank pulley to engage. I'm hoping it'll work.
Old May 29, 2015 | 03:38 AM
Good luck. Are you gonna put a new crank pulley on too?
Old Jun 29, 2015 | 12:55 PM
doughart1979's Avatar
I had a similar problem. Replaced the crank pulley as well. Got my parts from my local dealership. Honda Service Norwood Ma | Parts Center | Boch Honda Norwood
Old Jun 29, 2015 | 01:51 PM
bks84's Avatar
Loved
Pulley wasn't damaged, so no I didn't put another one on it.
devilpuppy
Aug 30, 2024 09:15 AM
civikdude
Feb 13, 2009 02:17 PM
DARKTEG_
Aug 13, 2006 03:15 PM
asefi944
Apr 11, 2005 02:26 PM
