problem with crankshaft sensor-swap from obd2 to obd1
Old Nov 1, 2003 | 03:50 AM
Civic's Avatar
Default problem with crankshaft sensor-swap from obd2 to obd1
ok, i started a topic about a week ago about doing a swap from obd2 to obd1, where only the block is involved. everyone told me that nothing needs to be changed electrically but the ecu jumper and ecu. now that i am taking everything apart, the obd2 block has a crankshaft sensor and the obd1 block doesn't. i know that without it, the car will run like crap. is it safe to drill into the obd1 block to modify it or what else can be done?
Old Nov 2, 2003 | 03:59 AM
Civic's Avatar
Default Re: problem with crankshaft sensor-swap from obd2 to obd1 (Civic)
anyone?
Old Nov 2, 2003 | 06:50 AM
ericrx_88's Avatar
if you using an obd1 ecu your ok it doesnot have a crank sensor just take it off or leave it. eric
Old Nov 2, 2003 | 08:28 AM
Civic's Avatar
Default Re: problem with crankshaft sensor-swap from obd2 to obd1 (ericrx_88)
no, for now, we'll be using an obd2 ecu.
Old Dec 14, 2003 | 11:27 AM
IDriveHonda's Avatar
I heard the obd1 cars have a crank fluctuation sensor built in to the distributor and that is why they have 2 plugs going to the dizzy. Is this correct?
Old Dec 14, 2003 | 11:50 AM
1700anddroping's Avatar
if your using and obd-2 computer,then yes you will have to use that crank angle sensor.all you have to do is buy a obd oil pump and put it on your obd 1 block and your done.if i were you i would just go ahead and spend the money and get the jumper harness and be done with it.
good luck with your set up.
Old Dec 14, 2003 | 11:51 AM
dam key boards. obd-2 oil pump.
honda2ksi
Jun 24, 2010 01:45 PM
strictly.business
Nov 25, 2006 09:05 PM
b20_ed
Nov 10, 2005 12:25 PM
whoa its len 2
Oct 2, 2004 07:18 AM
Ehron
Sep 22, 2002 09:51 PM
