Crane Cams ignition...
Old Sep 22, 2002 | 09:07 PM
flip1199's Avatar
Default Crane Cams ignition...
Ok on there hi6 ignitions there are two rmp dials, one is for a rev but i dont know what the other one is for??? The part numbers are 6000-6452 and 6000-6352. Also can anyone tell me which crane cam ignitions comes with a 2-step rev limiter???
Old Sep 23, 2002 | 06:46 AM
TimoneX's Avatar
New User
Default Re: Crane Cams ignition... (flip1199)
I may be mistaken here so don't quote me as gospel, but I think one dial is for the digital rev limiter and the other is for boost retard. It's been awhile since I messed with a crane ignition though. Is that the HI6 you got?
Old Sep 23, 2002 | 12:02 PM
flip1199's Avatar
Default Re: Crane Cams ignition... (TimoneX)
I haven't gotten it yet, i just wanted to check which one comes with the 2-step. Does anybody know the part number for the crane cam ignition that comes with the 2-step?
Old Sep 24, 2002 | 07:47 AM
Project X's Avatar
The 2 dials are for the single-stage rev-limiter. The left one is for "1000" rpm range and the right is for "100" rpm range. That means if you set your left one to 8 and right one to 5 then your spark cutoff will be 8500 rpm.
Old Sep 12, 2006 | 08:09 PM
BioXide02's Avatar
Default Re: Crane Cams ignition... (Project X)
Didn't want to start a new thread, so I am bumping this one!
Can you use a Crane Cams Hi-6 PN 6000-6420 as a two step? Any way to make it work.. or is it a lost cause??
Old Sep 13, 2006 | 06:33 AM
ykracing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project X &raquo;</TD></TR><TR><TD CLASS="quote">
The 2 dials are for the single-stage rev-limiter. The left one is for "1000" rpm range and the right is for "100" rpm range. That means if you set your left one to 8 and right one to 5 then your spark cutoff will be 8500 rpm.</TD></TR></TABLE>
correct!
Old Sep 13, 2006 | 07:03 AM
BioXide02's Avatar
Default Re: Crane Cams ignition... (BioXide02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BioXide02 &raquo;</TD></TR><TR><TD CLASS="quote">
Can you use a Crane Cams Hi-6 PN 6000-6420 as a two step? Any way to make it work.. or is it a lost cause??</TD></TR></TABLE>
Old Sep 13, 2006 | 07:36 AM
ykracing's Avatar
dont think so... I think that their two step option had a "TR" in the part number or something.. the basic ignitions dont have it.
Old Sep 13, 2006 | 09:56 AM
BioXide02's Avatar
Default Re: Crane Cams ignition... (ykracing)
Darn, Thanks for the info.. My friend picked one of these up from someone and he was wanting to use it for 2-step. Oh well.
maxboost_50psi
Dec 1, 2005 09:43 PM
Si Integra
Jan 31, 2004 08:13 AM
HotRodTeg
Sep 30, 2002 08:48 AM
Agamemnon
Mar 4, 2002 07:35 PM
