cp piston
Old Apr 28, 2005 | 11:03 PM
White_EK49's Avatar
Default cp piston
i need some help in filing my piston ring gap. it's 84.5 CP 9:1 Compression
bore size is 3.327. what is a good ring filer/grinder? what do I file the top ring to and what is the second ring? I have been told .017 for top and .017 for the second ring. That sounds kinda fishy. any info would help. Thank you!
Old Apr 28, 2005 | 11:38 PM
Kendall's Avatar
Have you called CP and asked them yet?
Old Apr 29, 2005 | 10:45 AM
White_EK49's Avatar
Default Re: (Kendall)
Okay I called CP this morning and the tech didn't know what spec to file them at. It was with hesitation then he said for the top ring. .020-.022 the middle or second ring. .024-.026 that seems like a large gap. Anyone has ever filed this ring. please help me out. Another person said top is .018 and middle is .022. other said. .017 for top and middle. please shed some light!
Old Apr 29, 2005 | 02:54 PM
SOHCmaster's Avatar
depends on the type silicone your piston is for one, high compression, turbo, each requires a correct gap due to metal expansion etc.,.....
Old Apr 29, 2005 | 11:09 PM
White_EK49's Avatar
Default Re: (PK SPEED)
i know of the silicon content. i just need some one who has cp piston shed some light here. It's for turbo, of course. 9:1 compression, 84.5mm inverted dome style. I need ring gap numbers. some one with fact. I could appreciate some real life experience. Thanks again. slow
Old Apr 30, 2005 | 11:42 AM
Garcia-Racing's Avatar
I do 18 on top 20 on middle on race motors, 17 and 19 on street.
Old Apr 30, 2005 | 12:31 PM
White_EK49's Avatar
Default Re: (Garcia-Racing)
Thanks, I knew some one with experience would come through. I was dissappointed you didn't get to run your car at CMI. All that driving from socal. Goodluck I hope you break the 9's this year.
Old Apr 30, 2005 | 03:35 PM
Thanks. I'm making a lot of changes to make it ET better. The mph was definitely there @156 buteverything wasn'y jiving toghether. It'll be back for Fontana.
datsun71
Jul 1, 2011 08:50 PM
tobster
Jan 22, 2010 05:10 PM
ericrx_88
Jun 1, 2005 11:34 PM
Seraph0
Jan 10, 2004 05:40 PM
