could a machine shop?...
Old Nov 20, 2002 | 05:41 AM
thinkbrianthink bu's Avatar
Default could a machine shop?...
There are grooves cut into the body of koni yellows which let you select a perch height. Would a machine shop be capable of cutting more grooves as evenly and precisely as the original grooves?
Old Nov 20, 2002 | 06:37 AM
advanracing62's Avatar
Default Re: could a machine shop?... (thinkbrianthink)
I would assume so... You may also be able to accomplish the same thing using a pipe cutter... and some care
Old Nov 20, 2002 | 06:58 AM
Default Re: could a machine shop?... (advanracing62)
anyone else know for sure?
its a pretty precise groove. it doesnt look rounded in the groove either. the bottom of the groove is squared off for a precise fit of the ring. i suppose it could be compared to cutting new grooves in pistons for rings.
Old Nov 20, 2002 | 09:20 AM
up
Old Nov 20, 2002 | 11:00 AM
brian b's Avatar
New User
A decent machine shop can cut anything you want at any angle within .001" in most any material..
Qiko_CB7
Welding / Fabrication
Apr 17, 2015 08:58 AM
dokdok
Nov 3, 2011 09:57 PM
bnmm
Jan 1, 2011 09:55 AM
#1rudebwoy
Jul 24, 2010 11:35 AM
