cooling problems... please help!
Old Nov 21, 2008 | 05:23 AM
thegatekeeper14's Avatar
Icon2 cooling problems... please help!
so i live up here in the cold and when ever its like 10 degrees or below my car always over heats. i have coolant in there with no air bubbles, i bleed the system . when its warm outside i have no problems. on cold days like this i dont have any heat either. what do you guys think the problem/s is?
thanks.
Old Nov 21, 2008 | 01:36 PM
Perfectionist's Avatar
Have your coolant tested for freeze point. I'll bet it's slushing up on you. Better do it sooner than later to prevent major damage.
Old Nov 21, 2008 | 07:55 PM
EnjoyTheRideDC2's Avatar
I would invest in an OEM Block heater. Helps bring your block to a higher temperature before starting.
I've never heard of coolant slushing up, but maybe if the mixture of water and coolant is not 50/50, and its more water than coolant, then the water might be freezing up?????
dth0ng69
18
Jul 19, 2009 09:12 AM
vinceiscoo
12
Sep 5, 2008 11:02 AM
Hondaciv95VX
Jan 13, 2005 07:21 PM
TurBoXBirD16
11
Mar 20, 2003 01:55 PM
delSolLS
Jan 16, 2002 01:06 PM
