Coolant question
Old Aug 15, 2016 | 04:09 PM
Sheraizzle's Avatar
Default Coolant question
My coolant was at the min level the other day and I added coolant this afternoon and accidently added too much. Is this going to be bad for my car and is there anything I can do to fix it?
Old Aug 15, 2016 | 09:30 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Coolant question
Take a turkey baster and suck coolant out of the reservoir until it's jsut below the max line when the engine is cold.
Old Aug 15, 2016 | 09:32 PM
Sheraizzle's Avatar
Thanks
Old Aug 16, 2016 | 10:03 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
It needs to be around the minimum line when cold. When hot, some of the coolant might come out into the reservoir, taking it up near the Max line. If it's at Max when cold, you could have overflowing problems.
Old Aug 16, 2016 | 11:10 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I've never experienced this. I've always made sure my coolant is just below the max line when cold. It then expands to be just under tip top full when hot, unless there is another issue such as boil over, head gasket issues etc.
-------------------- However ----------------------------
Thanks for pointing this out! FSM bleed method states to fill reservoir to MAX line after the engine is fully warmed up after the complete bleeding procedure. I never noticed this detail!
This indicates the coolant should be no higher than the max line at operating temperature. *good to know*
Old Aug 16, 2016 | 12:27 PM
Community Builder
Yep, exactly. Coolant in the tank should stay between Min and Max lines at all times.
Hardedge
Jan 8, 2008 05:59 PM
sam0218
Dec 8, 2006 02:27 PM
peel17
May 17, 2005 08:50 AM
ScottEK
Oct 30, 2002 09:42 PM
GruvyTune
May 24, 2002 03:17 PM
