Coolant question
My coolant was at the min level the other day and I added coolant this afternoon and accidently added too much. Is this going to be bad for my car and is there anything I can do to fix it?
It needs to be around the minimum line when cold. When hot, some of the coolant might come out into the reservoir, taking it up near the Max line. If it's at Max when cold, you could have overflowing problems.
-------------------- However ----------------------------
Thanks for pointing this out! FSM bleed method states to fill reservoir to MAX line after the engine is fully warmed up after the complete bleeding procedure. I never noticed this detail!
This indicates the coolant should be no higher than the max line at operating temperature. *good to know*
ScottEK
Oct 30, 2002 09:42 PM
GruvyTune
May 24, 2002 03:17 PM
