coolant question
coolant question
hey H-T, i have a couple quick questions about coolant.
1.) i have a conatiner filled with my previous coolant from before my engine swap, been sitting around for 2 weeks, can/should i still use this?
2.) where exactly are you suppose to dispose of coolant properly? where do YOU dispose of coolant?
thanks for any info
-quikflip
thanks for any info
-quikflip
Re: coolant question (quikflip27)
so you flushed the system from your old and still have the same coolant for your other motor?...shouldnt be a problem as long as you putt your coolant in a CLEAN container you'll be fine just add wtv needed more...once you put it back in put the rad cap off start it and let the coolant circulate.
replying back about adams grip night. Sorry i was in a rush and my thread got deleted. So is $25 dollars a session. One session is 1 hour. You will being doing 3 full laps and back to the pits. 1 lap take a little over 1 minute. So each run you do should be about a little over 3 min. You should get about 15-30 runs depending how many people is in each session. Eventually we'll make it better, but we're just going to try it out for now. Sorry if is sounds so confusing
Maybe try this, too: http://earth911.com/automotive/car-fluids/
take it to your local pep boys or any auto place they will usually let you dump it there. i know in maryland i take it there dump it with thier old oil and all then sign a recycling slip.
Fuzbal
Honda Civic (2001 - 2005)
10-20-2012 04:19 PM
eL
09-23-2004 06:25 PM
