Coolant in block...
Old May 3, 2005 | 09:01 AM
1bar_ek's Avatar
Default Coolant in block...
Had coolant spilling out from where the head and block meets. I think I might have a head gasket leak, took off the head, and found out that I have some coolant that went into my block. Drained all the coolant and oil out. Would there be a big problem if the coolant went into my block???
Old May 3, 2005 | 09:07 AM
Lord Helmet's Avatar
Default Re: Coolant in block... (darkside_ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkside_ek &raquo;</TD></TR><TR><TD CLASS="quote">Had coolant spilling out from where the head and block meets. I think I might have a head gasket leak, took off the head, and found out that I have some coolant that went into my block. Drained all the coolant and oil out. Would there be a big problem if the coolant went into my block???</TD></TR></TABLE>
ahh there is suppose to be coolant passages in the block. that's why you have coolant in the block.
Old May 3, 2005 | 09:12 AM
zacdaddy77's Avatar
are you saying it got in the cylinders ? if so it can hurt it by washing you cylinder walls if you still got the head off I would try oiling everything up real good ,put new oil in it and change it again soon so it gets all the coolant out
am sure someone else will have a comment
Old May 7, 2005 | 07:57 AM
1bar_ek's Avatar
Default Re: Coolant in block... (zacdaddy77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zacdaddy77 &raquo;</TD></TR><TR><TD CLASS="quote">are you saying it got in the cylinders ? if so it can hurt it by washing you cylinder walls if you still got the head off I would try oiling everything up real good ,put new oil in it and change it again soon so it gets all the coolant out
am sure someone else will have a comment</TD></TR></TABLE>
thanks for your pm.
OH_1fstgsr
14
Jul 21, 2008 06:03 PM
shreddinryguy
Aug 1, 2005 07:31 PM
TEXN3
Jan 24, 2004 04:33 PM
3rdGteg
Oct 24, 2002 05:30 AM
