computer question
Old Dec 28, 2004 | 06:19 PM
hatchpat's Avatar
Default computer question
I have a 1998 Civic H/b, I put a 2000 Civic EX engine in and kept the DX wiring harness. I just picked up a 2000 Civic EX computer and a harness to change OBDIIA to OBDIIB and to use the EXs full potential (along with V-Tech).
I plugged the new computer and harness in and it is doing something weird.
At idle, it pulses from 1500 to 1600 Rpms, and when I give it gas, it only goes to 5000 Rpms.
Does anyone have a solution to my problem?
Please?
pattummillo@hotmail.com
thankx
Old Dec 28, 2004 | 06:29 PM
eda6's Avatar
Default Re: computer question (hatchpat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchpat &raquo;</TD></TR><TR><TD CLASS="quote">I just picked up a 2000 Civic EX computer and a harness to change OBDIIA to OBDIIB and to use the EXs full potential (along with V-Tech).</TD></TR></TABLE>
To use the full potential of your EX along with VTEC you should have gone obd1
Old Dec 29, 2004 | 06:00 AM
tgreaves's Avatar
It is throwing any codes?
Old Dec 29, 2004 | 10:54 AM
spoonek9's Avatar
The IACs are different and need to be wired correctly. You should also be throwing a code 91 as well and did you hook your secondary oxygen sensor up?
Old Dec 29, 2004 | 12:33 PM
hatchpat's Avatar
Default Re: computer question (spoonek9)
Yes, I'll give that a try.
hope it works.
If I got a harness for an OBDIIA to OBDI, would I have to alter anyhting or is is a direct changeover?
Old Jan 1, 2005 | 01:16 PM
hatchpat's Avatar
what do you mean the IACs are different.
The engine = 2000 ex
the wiring = 1998 dx
the computer = 2000 ex
Old Jan 1, 2005 | 07:03 PM
civic-4-ges's Avatar
Default Re: computer question (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">It is throwing any codes?</TD></TR></TABLE>
This is important....like someone above said, there are different IACV's for the Vtec and non-vtec models. You should be throwing a cel code 14.
You need to source a plug and do the IACv plug fix. There is a diagram somewhere here on Honda-Tech.
Old Jan 2, 2005 | 10:57 AM
hatchpat's Avatar
Default Re: computer question (civic-4-ges)
you wouldn't happen to know where that diagram is do you?
The one different wire, is an orange wire.
would it be wrong to just cut this wire and leave it hanging or should I cut it and ground it out?
Old Jan 8, 2005 | 03:39 PM
hatchpat's Avatar
well, I haven't had the time to do anything yet, the snow came and motivation left.
so I am still waiting, I think I will have it under control, but if I don't, I'll come back here to seek more knowledge.
thanks for all your help.
illios
May 18, 2010 02:20 PM
96hatch96
Apr 9, 2007 12:12 PM
StOnErTuNinG
Jul 29, 2006 10:05 AM
hatchpat
Jan 8, 2005 03:36 PM
turboex
Dec 7, 2002 08:49 AM
