comptech sway/tie bar install - knocking noise
Old Aug 15, 2003 | 06:25 PM
crr's Avatar
crr
Default comptech sway/tie bar install - knocking noise
just did the comptech sway/tie bar install, and now I'm getting a strange knocking noise from the rear. I was careful to tighten everything according to spec.
I also have ground controls sitting on Bilsteins, and I lowered the GCs an extra 1/4" after the sway bar install. Not sure which is causing the knock.
Anybody have a similar experience with either setup?
thanks.
98 Intregra RS
Old Aug 15, 2003 | 07:02 PM
Benny Hinn's Avatar
Default Re: comptech sway/tie bar install - knocking noise (crr)
Is your swaybar hitting the exhuast?
Old Aug 15, 2003 | 07:36 PM
crr's Avatar
crr
Default Re: comptech sway/tie bar install - knocking noise (Benny Hinn)
no, it doesn't appear to be. I seem to hear the knocking noise on both sides. I can even make the noise happen (sometimes) by jerking the wheel to each side.
It can even happen at very slow speed - driveway speed, say. I'm wondering if something is just binding up, perhaps the end links or the bar within the bushing for example.
I don't notice any performance problems. In fact, the handling feels great.
Old Aug 16, 2003 | 07:05 AM
PupaScoopa's Avatar
Yep, I've had mine for years and it does the same; and has since day one. It's the endlinks that make the noise.
Old Aug 16, 2003 | 10:07 AM
owen_the_soyboy's Avatar
Default Re: comptech sway/tie bar install - knocking noise (PupaScoopa)
swaybar upside down?
Old Aug 16, 2003 | 10:31 AM
bushfreakz's Avatar
my exhaust (apexi ws) rattled up on my rear sway bar.. and it was stock.. would be worse if it was bigger.. couldnt tell when the car was jacked up cause it was relieved of pressure...
wiggle your exhaust back and forth maybe
Old Aug 16, 2003 | 05:57 PM
crr's Avatar
crr
hey thanks, Pupa. I'm noticing today that it's quiet over 30 or 40mph. In fact, I seem to only hear it at fairly slow speeds. Is that your experience too?
Old Aug 17, 2003 | 12:48 AM
ransack's Avatar
that noise would be your endlinks.
it makes that knocking noise.
I THINK comptech might have some replacement or new endlinks. call them to find out what you can do exactly
Old Aug 17, 2003 | 12:19 PM
jcda6's Avatar
Comptech adjustable endlinks are known to be "noisy" due to the spherical bearing binding. Comptech is coming out with new and improved endlinks and I've also heard they are testing the sway bars with OEM style endlinks as well to remedy the problem.
-Jeff C.
Old Aug 17, 2003 | 05:42 PM
crr's Avatar
crr
Default Re: comptech sway/tie bar install - knocking noise (jcda6)
thanks all. believe it or not, the noise seems to be going away on day-3 after the install.
Old Aug 19, 2003 | 09:10 AM
Dr. EKology's Avatar
Just saw this thread in a search that I did and I remember seeing in another thread that Si Endlinks WILL work!! Let me find you guys a link....
Edit: Here's the link fellas https://honda-tech.com/zerothread?id=586612&page=2
Old Mar 30, 2004 | 03:37 AM
1SlowSi's Avatar
Default Re: comptech sway/tie bar install - knocking noise (EVIL_EKology)
when you buy the kit, does it come with new endlinks? i hear that knocking noise on my damn Si, only when someone is in the back seat though. i have skunk 2 camber kit, AGX shocks, rear lower and upper tie bar. any guesses?
2003 ES1
Honda Civic (2001 - 2005)
Feb 20, 2013 03:26 AM
yuning83
Honda Civic (2006 - 2015)
Aug 15, 2007 05:14 PM
Built to Spill
12
Jun 17, 2004 04:49 AM
SystemGSR
Oct 31, 2001 10:29 PM
Scooby
Sep 4, 2001 02:34 PM
