compression testing! need info
Old Apr 11, 2004 | 02:30 PM
projektCRX's Avatar
Default compression testing! need info
is there a specific compression tester that works best for honda motors??????
any posts would help!
Old Apr 11, 2004 | 05:22 PM
SleepyHF's Avatar
Default Re: compression testing! need info (projektCRX)
any would be fine....use SEARCH too
Old Apr 12, 2004 | 06:08 PM
projektCRX's Avatar
cooh thanks, i wanna turbo it, har har... but i dun evn kno if my b18b1 is in good shape too...
Old Apr 12, 2004 | 08:18 PM
BuddhaSiR's Avatar
what is the correct way to test compression? Crank the motor at wideopen throttle for 5 compression strokes or till the needle stops increasing?
Old Apr 12, 2004 | 08:25 PM
mmuller's Avatar
Mad Scientist
Default Re: compression testing! need info (BuddhaSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BuddhaSiR &raquo;</TD></TR><TR><TD CLASS="quote">what is the correct way to test compression? Crank the motor at wideopen throttle for 5 compression strokes or till the needle stops increasing? </TD></TR></TABLE>
I usually crank the car 7 or 8 times.Or untill compression stops increasing majorly
Old Apr 21, 2004 | 01:03 AM
projektCRX's Avatar
Default compression test results! ??
i posted in a different thread but i dont know if this is good or bad..
https://honda-tech.com/zerothread?id=840197
Old Apr 21, 2004 | 07:25 AM
blackeg's Avatar
Default Re: compression test results! ?? (projektCRX)
at normal operating temps, pull the sparkplugs and either pull the fuel pump relay or what i do is just unplug the injector clips. put the pressure gauge in the spark plug hole, make sure it reads 0, then crank it over. i crank 7 times, but some people do like 5. make sure you are keepin the car at wot while you are cranking. very good that you are checking before using forced induction.
Old Apr 21, 2004 | 10:59 PM
BuddhaSiR's Avatar
Default Re: compression test results! ?? (blackeg)
5 or 7 times around could be a difference of 40 psi. so then would you go with the 7 times around number?
Old Apr 21, 2004 | 11:05 PM
mmuller's Avatar
Mad Scientist
Default Re: compression test results! ?? (BuddhaSiR)
just crank untill the psi's stop going up greatly
Old Apr 21, 2004 | 11:12 PM
BuddhaSiR's Avatar
Default Re: compression test results! ?? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">just crank untill the psi's stop going up greatly</TD></TR></TABLE>
thats kinda what i figure
Old Apr 22, 2004 | 12:20 PM
projektCRX's Avatar
DOPE! thanks fer ur guys help!....i have to start a new trhead for my hidious turbo questions, hahaha.. thank you1!!
ChronicGreenDC2
Jun 24, 2005 09:30 AM
92BlackSi
17
Apr 10, 2005 07:30 PM
Mr.Integra
Apr 22, 2004 07:55 PM
builtprelude
Jan 22, 2004 10:49 PM
