Compression Test RESULTS!! Low??
Old Apr 20, 2004 | 09:07 PM
ozzyman's Avatar
Default Compression Test RESULTS!! Low?? **UPDATED NEW RESULTS!!**
Motor is a OBD1 JDM H22A. Not sure exactly how many miles. Here are the compression results:
#1 - 165
#2 - 155
#3 - 155
#4 - 155
Not exactly sure if this is too low or not. Also did a cylinder leak down test afterwards and held pressure no problem. Any input??
EDIT: Alright, so I did the test again this time with the throttle wide open. I got 230 all the way across. So these are pretty good numbers, yeah?
Modified by ozzyman at 3:39 AM 4/22/2004
Old Apr 20, 2004 | 09:23 PM
ozzyman's Avatar
Default Re: Compression Test RESULTS!! Low?? (ozzyman)
Anyone??
Old Apr 20, 2004 | 09:43 PM
SleepyHF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ozzyman &raquo;</TD></TR><TR><TD CLASS="quote">Motor is a OBD1 JDM H22A. Not sure exactly how many miles. Here are the compression results:
#1 - 165
#2 - 155
#3 - 155
#4 - 155
Not exactly sure if this is too low or not. Also did a cylinder leak down test afterwards and held pressure no problem. Any input??</TD></TR></TABLE>
That is fine. If you ever do a compression test, and the results are like a 20 spread then something is wrong. Those numbers seem to look fine
Old Apr 20, 2004 | 09:44 PM
ozzyman's Avatar
Default Re: Compression Test RESULTS!! Low?? (SleepyHF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepyHF &raquo;</TD></TR><TR><TD CLASS="quote">
That is fine. If you ever do a compression test, and the results are like a 20 spread then something is wrong. Those numbers seem to look fine </TD></TR></TABLE>
Thanks man. Good lookin out.
Old Apr 20, 2004 | 10:14 PM
blackeg's Avatar
ok, they are low, but also consistent. since you said all cyls held air fine, i wouldnt be too concerned
Old Apr 20, 2004 | 10:17 PM
ozzyman's Avatar
Default Re: Compression Test RESULTS!! Low?? (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">ok, they are low, but also consistent. since you said all cyls held air fine, i wouldnt be too concerned</TD></TR></TABLE>
Alright, Thanks.
Old Apr 20, 2004 | 10:41 PM
mmuller's Avatar
Mad Scientist
did you hold the throttle open?
#'s are even, but low.
Old Apr 20, 2004 | 11:01 PM
ozzyman's Avatar
Default Re: Compression Test RESULTS!! Low?? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">did you hold the throttle open?
Hold the throttle open?? No I didnt. Whats the point in this?
Old Apr 20, 2004 | 11:15 PM
irev210's Avatar
numbers are looking way low... is this cold?
Warm H22 w/ open throttle body... we were getting on 280 across all 4 on a bone stock H22.
Mind you all compression testers are different... but honestly a LS motor will compression test at 180... type R motor will hit 220+ with ease... JDM type R will hit up there with the H22's...
They are compression monsters.
When you do a compression test... have the driver floor the gas pedal... otherwise you are trying to fill up the cylinders with only letting a straw sized amount of air in.
Anyway if you are doing a proper compression test, go to a dyno and see what type of #'s you lay down and how much oil you consume.
Old Apr 20, 2004 | 11:48 PM
ozzyman's Avatar
Default Re: Compression Test RESULTS!! Low?? (irev210)
What I did was take out my ECM 15 amp fuse, and just turn the motor over 5 times. I didn't know I was supposed to floor the gas pedal. Would that bring my compression up if I floored it?? Also our compression tester only reads up to 250.
Old Apr 21, 2004 | 07:27 AM
blackeg's Avatar
yea its supposed to be done at wide open throttle and at normal engine operating temperature
Old Apr 21, 2004 | 08:34 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ozzyman &raquo;</TD></TR><TR><TD CLASS="quote">... I didn't know I was supposed to floor the gas pedal. Would that bring my compression up if I floored it??</TD></TR></TABLE>Yes it would. Crank till the pressure stops increasing.
But remember, compression gauges are different. If your gauge has a larger internal volume, that'll make it read lower.
Old Apr 21, 2004 | 09:36 AM
ozzyman's Avatar
Default Re: Compression Test RESULTS!! Low?? (JimBlake)
Thanks for the reply guys. I'll do another compression test if I have time today.
Old Apr 21, 2004 | 06:39 PM
ozzyman's Avatar
Default Re: Compression Test RESULTS!! Low?? **UPDATED NEW RESULTS!!** (ozzyman)
TTTTTTTTTTTTTT
Old Apr 21, 2004 | 06:57 PM
GZERO's Avatar
Modified by ozzyman at 3:39 AM 4/22/2004</TD></TR></TABLE>
sounds good to me, if you want to see if your rings are a lil worn, throw a lil (like a teaspoon) of oil in each cilinder and read pressure.
Remember:
WOT
Crank it till the number won't go higher
Take all spark plugs so the starter won't have to overcome much compression
Warm engine
Disconect spark anyway you can
Old Apr 21, 2004 | 07:18 PM
ozzyman's Avatar
Default Re: Compression Test RESULTS!! Low?? **UPDATED NEW RESULTS!!** (GZERO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GZERO &raquo;</TD></TR><TR><TD CLASS="quote">
Remember:
WOT
Warm engine
Thanks man. Good lookin out man.
Old Apr 22, 2004 | 04:29 AM
b18c1civic95's Avatar
well either your motor and mine are pieces of crap or were normal cuz i got the same thing 2 days ago when we did a compression test. its a jdm h23/vtec. but hey mines doesn't work right now and i dont know why.
Old Apr 22, 2004 | 06:19 AM
JimBlake's Avatar
Default Re: Compression Test RESULTS!! Low?? **UPDATED NEW RESULTS!!** (b18c1civic95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GZERO &raquo;</TD></TR><TR><TD CLASS="quote">... Disconect spark anyway you can</TD></TR></TABLE>Disconnect fuel, too. You can probably pull an ecu fuse somewhere to disable both.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c1civic95 &raquo;</TD></TR><TR><TD CLASS="quote">... cuz i got the same thing 2 days ago when we did a compression test. its a jdm h23/vtec. but hey mines doesn't work right now and i dont know why.</TD></TR></TABLE>If you get 230 compression on all 4, then you know it's NOT because of bad compression...
Tonydalude
Apr 10, 2005 08:31 PM
quaker
Jan 5, 2005 05:33 AM
projektCRX
Apr 22, 2004 12:18 PM
ozzyman
Apr 22, 2004 10:12 AM
