bad injector/injectors???
Old Apr 22, 2004 | 06:31 AM
d16y8turbo's Avatar
Default bad injector/injectors???
what are the symptoms of bad injectors?
my car is making a very loud clicking sounds coming from what appears to be te head. i took te head off and took it apart completely, and everything appeared to be normal.
the car won't run rich no matter what i do, and i have 440cc injectors AND i put my fmu back on to try to step up fuel pressure. i have an afc, and i'm leaned out 40% at idle, and up to at only 10psi i'm leaned out 15%.
usually my a/f guage will show lean/stoich at idle and normal driving, and go full rich at wot; but not anymore. is it possible for bad injectors to make a lot of noise? does it sound like that's the prob?
what other probs could these symptoms be?
the clicking sound started happening when i blew my head gasket and the temp needle almost maxxed out, so i'm pretty sure it's head related. what could it be?
Old Apr 22, 2004 | 06:41 AM
kur0ryu's Avatar
Default Re: bad injector/injectors??? (d16y8turbo)
possibly valve tapping? maybe you're in serious need of a valve adjustment...?
Si Shane
Sep 16, 2005 09:55 AM
CaptivaBlue
Jun 19, 2005 09:54 PM
LSegHatchy
Jun 19, 2005 04:19 PM
Mr. Vapor
May 7, 2005 12:57 AM
Lee_Delso
Jan 20, 2005 02:14 PM
