compression test questions....
how accurate are they on a motor that is out of the car? Would a dented oil pan / pick up skew results?
Im thinking you cant really get a good compression on a motor that has been sitting for god knows how long, but I may be wrong.
Total newbie at this so any information is greatly appreciated.
Monty
Monty
get the engine to normal op temp, remove the sparks, install the compression tester in #1, crank the engine by hand with the motor off 6 revolutions. If it is kind Repeat in each cyl. A healthy engine will get up to comp. Quickly, slow numbers come from bad valves, rod bearings or piston rings. Check with a tech as to his opinions once you get your readings.
[Modified by MikeSarr_GSR, 11:43 AM 4/28/2002]
Proper comp. test should be done with the eng. warm. Since it's out of the car, you can't do that. BUT if the numbers are within 10% of each other doing it cold, you have a good chance. A dented pan (and maybe the oil pick-up, also), must be repaired before installing the engine. It can easily pinch off most of the oil to your engine if u run it that way.
InLimbo87
Nov 4, 2004 05:05 PM
builtprelude
Jan 22, 2004 10:49 PM
