Compression Test
Old Apr 21, 2011 | 04:40 PM
vitamin_c95's Avatar
Default Compression Test
I did on a cold engine, then on a hot immediately afterwards. I cranked it 6 revolutions. Tell me your suggestions. Original complaint is that I use a lot of oil, blue smoke on acceleration, sometimes light smoke when idling. Power seems strong. I havent noticed any power drop. Plugs looked better now that I have replaced valve seals and new coil. Before they were a sooty black, now they are just dark. These are new plugs and wires after doing my valve seals about a month ago. Middle two plugs were slighly wet, smelled like fuel, even though I havnt driven this car in about 9 days. I think I know what I need to know what needs to be done, just verifying with a general consensus. Unknown miles on this 96 B18C. Thanks fellas.
COLD ENGINE
dry Wet
1 215 250
2 205 245
3 205 235
4 205 230
WARM ENGINE
1 220 260
2 210 245
3 215 235
4 215 245
Cspeed racing states 200 psi is acceptable, which is the only specs I have found so far for a B18C. Im still googling etc. Thanks fellas
Old Apr 22, 2011 | 07:49 AM
fcm's Avatar
fcm
Old Fart
Default Re: Compression Test
Compression looks pretty good, all within 10% of each other and well above lower limits. 94
Old Apr 24, 2011 | 12:57 AM
blackedEk's Avatar
agreed
Old Apr 24, 2011 | 05:07 AM
so probably my oil rings gone? 200 psi is the min for a jdm correct?
Old Apr 24, 2011 | 07:29 AM
frankenghia's Avatar
possibly oil rings.... also if the valve guides are worn too bad then seals wont help.
Old Apr 24, 2011 | 09:27 AM
Atomic1's Avatar
Compression tests tell you NOTHING about the condition of the oil control rings. You can have good compression and have worn or stuck oil rings. Since you have burning oil on acceleration and idling, it's almost certainly your oil rings. The extra labor spent on just replacing the valve stem seals was wasted. This should have been a rebuild from the start if the goal is to solve major oil consumption.
Old Apr 24, 2011 | 09:56 AM
fcm's Avatar
fcm
Old Fart
Although I agree this is most likely an oil ring issue and once the head was pulled they should at least have been checked, I disagree that doing the valve seals was a wasted anything, [it is the least I would do if I had to pull a head for any reason] not checking/doing the rings once the head was pulled was a wasted opportunity, that will cost time, effort and money, but the valve seals will not have to be redone, so not wasted, JMO. 94
Old Apr 24, 2011 | 05:33 PM
I did the valve seals with the head still installed via air pressure. Being how it was smoking first thing in the morning, I was hoping it was my only problem. As atomic stated, I was asking since my compression is still acceptable, if it would be the oil rings. regardless now it looks like a teardown. Guess im gonna start piecing together my engine
Trina Martinez
Honda Fit
Oct 27, 2016 07:58 PM
jeffkong11
Oct 19, 2012 04:29 PM
civtic
Mar 6, 2008 10:22 PM
typeeg
Jun 9, 2004 08:14 AM
Aeka GSR
Oct 4, 2002 11:44 PM
