Compression Results
Old Feb 12, 2003 | 10:05 AM
SixPAK's Avatar
New User
Default Compression Results
D16Y8 motor.
First Try:
cyl1: 200
cyl2: 195
cyl3: 190
cyl4: 190
Second Try:
cyl1: 190
cyl2: 190
cyl3: 190
cyl4: 190
Could this be because the motor was cooling down during the test? I did it in those exact orders.
What are considered good numbers for the D16Y8? I know the consistence is a good thing.
Old Feb 12, 2003 | 12:33 PM
tpr's Avatar
tpr
Default Re: Compression Results (SixPAK)
First did you have the throttle at WOT (wide open throttle) and yes compression should be measured cold or hot but not changing. That may be the reason for the difference.
cilvia
17
Dec 31, 2023 08:00 PM
yoffer
Apr 3, 2007 08:34 PM
tobe1424
Dec 6, 2005 09:02 PM
