Compression question!
Old Nov 8, 2002 | 11:31 AM
99YZF's Avatar
Default Compression question!
What is the highest compression I can run on 92 octane pump gas? Want to run 11:1, but think it's too high. Maybe Mike could help me.
Old Nov 8, 2002 | 12:25 PM
teal_dx's Avatar
Default Re: Compression question! (sir2crx)
11:1 will work on pump gas with the correct timing adj. I run 92 octane w/ 11:1 no problems at all.
Old Nov 8, 2002 | 01:15 PM
Kataku2K3's Avatar
Default Re: Compression question! (teal_dx)
Tuning is everything.... I know a lot of people that run 12.5 on 92 with no detonation...
Old Nov 8, 2002 | 01:57 PM
10K2HVN's Avatar
Default Re: Compression question! (JDMspecEG6)
interesting, 12.5 on 92 maybe i might get 11.5 then...
anyways, since this is a "Compression" topic, i was wondering if anyone knew the compression ratio of a B20B with B16A2 head??? (stock internals)
oh *****, i just remembered i only get 91 around here, maybe 11:1 is good....
Old Nov 8, 2002 | 02:23 PM
Katman's Avatar
Default Re: Compression question! (10K2HVN)
Don't worry ... 91oct + 11.5cr will do you just fine daily driver. I'm personally running 11.5 and use 91 octane.
Old Nov 8, 2002 | 02:25 PM
10K2HVN's Avatar
Default Re: Compression question! (Katman)
KATMAN, are you the same "Katman" from "JDMHondaParts.com"???
..and thx for tha info...
Old Nov 8, 2002 | 02:29 PM
Kataku2K3's Avatar
Yep that's him, to Katman
Old Nov 8, 2002 | 03:46 PM
tinkerbell's Avatar
have a play here:
http://www.c-speedracing.com/howto/c.../compcalc.html
t..
PS tuning tuning tuning...
Old Nov 8, 2002 | 05:46 PM
10K2HVN's Avatar
Default Re: Compression question! (tinkerbell)
CooL ThankS!!!
Old Nov 8, 2002 | 05:52 PM
10K2HVN's Avatar
Crappy 9.3:1 compression ratio!!
Old Nov 9, 2002 | 12:14 AM
Kataku2K3's Avatar
If you got 9.3:1 just boost on it a bit, hehehe... Have fun Latez
Old Nov 9, 2002 | 12:42 AM
Jesse H's Avatar
I know of an ITR motor with a block guard, otherwise stock, running 6 lbs of boost on 93 with no detonation. Good tuner.
Old Nov 9, 2002 | 02:16 AM
infamousALLMTR's Avatar
Default Re: Compression question! (Jesse H)
13:1 is the highest I would go with correct time adjustment and bigger injectors
Shane
Old Nov 9, 2002 | 03:52 AM
tk's Avatar
tk
Default Re: Compression question! (infamousLSVTEC)
It depends on the acceleration speed of your motor
A slow reving motor can't have alot of compression and will ping even with 9.1 compression
A fast accelerating motor can go to 11.1-12.5 compression with good tuning and never ping
Ever drive a towing vehicle and when pulling a trailer she pings and when you're not pulling anything it doesn't
Acceleration is controled by gearing
[Modified by tk, 7:54 AM 11/9/2002]
Old Nov 9, 2002 | 07:07 PM
you can run 12:1 no prob around here josh
Old Nov 9, 2002 | 07:12 PM
QCKGSR's Avatar
you can run that much on pump gas just make sure your timing is suffiecient. and fuel pressure. start at 14 degreees
Old Nov 12, 2002 | 03:41 PM
Katman's Avatar
yesh, yesh I am.
Old Nov 12, 2002 | 04:39 PM
Kataku2K3's Avatar
My friend had a B16B in his 99 EK..... For the NHRA event in August he swapped it out for a stock ITR motor just to boost it... He just had it chilling in his garage forever so i guess he figured why not... He said he didn't care if it blew up... I dunno why i would. (rich people) The night before he hooked a RevHard Stage 2C turbo with a T3/T04E hybrid boosting 12psi... Ran some 440's on it with Hondata2 just for that day and he ran a 12.50@112.... Nothing special but not bad for a internally stock motor without any real tuning... With his previous CTR motor the best for the car was only a 13.3@104... Peace
Old Nov 13, 2002 | 02:30 PM
QCKGSR's Avatar
i run 13:1 on pump gas but the car is tuned with a fine tooth comb if you get what im saying. Spend some time trial amd error.
Old Nov 13, 2002 | 02:36 PM
azboy's Avatar
Default Re: Compression question! (QCKGSR)
if the Toyota Celica GT-S comes with stock 11.5:1 compression then one would think 11:1 would be fine on a honda.
Old Nov 18, 2002 | 04:42 PM
99YZF's Avatar
Thanks Mike.
Old Nov 19, 2002 | 04:40 PM
SIReg9's Avatar
Guy i talked to at JDMHONDAPARTS said he runs CTR pistons in his ITR motor with a 2 ply head gasket... 12.45 compression i think...on 91 octane...not sure how he tuned it. but he said its runnin strong. I was skeptical about factory pistons...but ive heard tooo many ppl say they were safe.
Old Nov 19, 2002 | 07:26 PM
Katman's Avatar
Default Re: Compression question! (SIReg9)
factory Honda pistons are safe, especially Type-R pistons, if you can't afford aftermarket pistons.
Old Jan 4, 2003 | 12:17 PM
99YZF's Avatar
I am thinking of going 12:1 compression. Do I need to upgrade my rods or are the stock B series rods strong enough to handle it?
Old Jan 4, 2003 | 02:56 PM
Kataku2K3's Avatar
What motor?? nonVTEC or VTEC... Really it's a good thing to upgrade non VTEC rods but I know of many people around here that use stock rods with ARP rod bolts... It's a good idea to also get them shot peened as well.... My friend's CRVTEC running 84.5mm 12.0:1 JE slugs and stock rods holds up just fine... I know all together too many of you have heard me say this but his CRVTEC in his full interior EK ran a 12.62@107.... He also only revs it to 8400... it's got a Portflow head, CTR intake cam, RC 310's, ITR ECU and VAFC (also has never been on the dyno).... As long as you are staying NA you should be fine... GSR and ITR rods are stronger than nonVTEC's so I see no reason why they wouldn't hold up.... Good Luck
limpy
Jun 27, 2005 01:04 AM
Wasabithegosu
May 25, 2005 03:55 AM
JdM_Eg_6
Mar 18, 2004 09:26 AM
Ink00
Sep 24, 2002 11:48 PM
blazin
Nov 16, 2001 03:14 PM
