compression ?
No way to tell by what information you have given. How much was milled off? Best way to tell is CC the combustion chamber and bottom-end with the piston at TDC. Add the volume of the headgasket... Take that total volume, divde it into that volume + your volume from the stroke of the crank and walla... There's your compression ratio.
allright !!!!! thanks TREVER how did you find that out what mathamatical equasion?
