Code 23 (knock sensor)..can't get rid of it..HELP
A friend of mine put a built B18C1 12.5 to 1 compression swap into his 90 CRX. He is running a PW0 chipped ecu. Ever since the swap has been completed, it has thrown a code 23 (Knock Sensor). He tried changing the knock sensor and it did not help. He also tried running the wire from the knock sensor straight to the ecu to make sure the wiring was correct. It didn't help. Anyone have any suggestions on what could be the problem?
That is pretty high compression. What kind of gas are you using? You are not using 91 octane are you? With that kind of compression I would suspect that you would have to run race gas. Try some high octane race gas(ie. 100+ octane) and see what happens. Race gas is a little expensive but I would still give it a try.
ddong2lee
Mar 4, 2004 05:06 AM
jdmciviceg
Jun 9, 2002 07:56 PM
