Code 22 on my new H swap??
Old Oct 11, 2008 | 06:21 PM
turboedsupe's Avatar
Default Code 22 on my new H swap??
Well i guess this code 22 is vtec pressure switch. I found a couple articles saying obd2 engines dont have them so you have to jump a couple wires to get the light off. But i ordered a obd1 jdm h22 for my EG. Why is this light on and how can it be fixed?
Old Oct 12, 2008 | 04:26 PM
Default Re: Code 22 on my new H swap?? (turboedsupe)
DO i even have a vtec pressure switch??
Old Oct 12, 2008 | 08:53 PM
crx-b18c's Avatar
you have jdm engine some dont bring pressure switch you need chipped ecu or usdm selenoid to fixed and good luck
Old Oct 13, 2008 | 02:16 PM
brightside's Avatar
Default Re: Code 22 on my new H swap?? (crx-b18c)
it looks like your pressure switch port is plugged up with a bolt/plug. you could remove that plug and take a pressure switch from another solenoid and plug it in. if you have a chipped ecu and crome w/ a burner, you could remove that CEL from coming on also.
jayeghatch
14
Sep 25, 2012 02:19 AM
prime-R
16
Apr 11, 2009 05:33 PM
mikehawk
Oct 26, 2008 03:41 PM
spyderracing
15
Oct 21, 2004 05:49 PM
Blake97GSR
Nov 7, 2003 06:01 AM
