Code 22, help?
Old Apr 25, 2004 | 03:23 PM
xerox445's Avatar
Default Code 22, help?
I've been throwing code 22 from time to time, last night it came on for good, wont go off anymore. Is this an easy fix?
Its 22 VTEC pressure valve, on 98 gsr motor running obd1, thanx.
Edit: Oil Level is Fine....
Old Apr 25, 2004 | 03:43 PM
2lua's Avatar
Default Re: Code 22, help? (xerox445)
check you plug, if it good then try to ohm (check continuity) the sensor to see if reading zero or not, if it read zero then it good and if it not then it bad. if sensor is good the remove the vtec assembly and check out the screen filter to see if it clogged or not.
Old Apr 25, 2004 | 03:55 PM
xerox445's Avatar
Default Re: Code 22, help? (2lua)
fixed it, the ground was loose, cleaned it up with a wire brush, put a new connector on, and regrounded it. Code gone, thanx again HT....
JDMTRSPORTS
Feb 17, 2006 02:02 PM
jdm stan
Aug 15, 2005 10:28 AM
gsr2envy
Nov 7, 2004 03:32 PM
integracivic94
Aug 22, 2004 08:42 AM
CLICC916
Jun 12, 2002 03:05 PM
